Trouble using atmBoundaryLayerInletVelocity
Old   December 4, 2019, 11:49
Default Trouble using atmBoundaryLayerInletVelocity
juvima is on a distinguished road
I'm working with OpenFOAM 6 and I'm trying to use the atmBoundaryLayerInletVelocity boundary condition in order to set a logarithmic velocity inlet for my simulation. My 0/U.orig reads:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
flowVelocity         (20 0 0);
pressure             0;
turbulentKE          0.24;
turbulentOmega       1.78;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform $flowVelocity;
boundaryField
    //- Set patchGroups for constraint patches
    #includeEtc "caseDicts/setConstraintTypes"
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           $internalField;
    inlet
    type atmBoundaryLayerInletVelocity;
    flowDir (1 0 0);
    zDir (0 0 1);
    Uref 20.0;
    Zref 2.0;
    z0 uniform 0.0002;
    zGround uniform 0.0;
    lowerWall
        type            noSlip;
    Panel_PV
        type            noSlip;
    upperWall
    type slip;
frontAndBack
    type slip;
This code produces this error:
--> FOAM FATAL IO ERROR:
Unknown patchField type atmBoundaryLayerInletVelocity for patch type patch
Valid patchField types are :
84
SRFFreestreamVelocity
SRFVelocity
file: /home/[current working directory]/0/U.boundaryField.inlet from line 40 to line 46.
    From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>]
    in file /home/linuxb102/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 134.
FOAM exiting
I understand that I need to tell to OpenFOAM where to find the source for atmBoundaryLayerInletVelocity but I have not been able to, and it's starting to drive me crazy. Am I doing this right? Is it a version problem I am missing?
Thank you very much!
juvima is offline   Reply With Quote
Old   December 5, 2019, 09:52
Bazinga is on a distinguished road
I can relate to your frustration. You are missing a library in system/controlDict
Check atmBoundaryLayerInletVelocity in OpenFOAM6
Bazinga is offline   Reply With Quote
Old   December 5, 2019, 12:43
It worked! Thanks you very much for your help!
atmboundarylayerinlet, boundaries condition, openfoam6
[waves2Foam] Having a lot of trouble for a short wavelengths arieljeds OpenFOAM Community Contributions 1 January 2, 2024 14:10
Trouble with rotating wall boundary condition king1989 OpenFOAM Running, Solving & CFD 7 July 29, 2016 14:44
Trouble with sampleDict syntax for OpenFOAM 2.3.1 rawdoggity OpenFOAM Post-Processing 1 February 1, 2015 06:24
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 08:38
[GAMBIT] Trouble meshing complex VOF geometry RPJones ANSYS Meshing & Geometry 2 February 14, 2011 19:54
