Tracer injection from a periodic boundary face |
November 29, 2019, 15:12 |
Paolo Bruno
Hello to all,
I am trying to model the injection of a tracer into a channel from the inlet. I am running a Large Eddy Simulation and, in order to avoid the dependence of results on the inlet turbulence intensity, I prescribed the inlet and outlet of the channel as periodic, using the "cyclic" boundary condition. Once the flow is stabilized, I would like to insert the tracer from the inlet as a pulse for a short period of time and obtain the residence time distribution (RTD). In the tracer file I defined the inlet type as "fixedValue" to fix the input value of the tracer, but when I run the simulation, an error tells me that I must define the inlet type as "cyclic". Can anyone suggest me how to insert the tracer into the channel from the inlet with cyclic boundary condition? Thanks for help in advance. |
cyclic bc, tracer |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
