Creating two overlapped meshes in the same case
Old   October 8, 2019, 18:13
Default Creating two overlapped meshes in the same case
Rishikesh
mrishi is on a distinguished road
Greetings!
I would like to create two meshes of the domain, with different refinements. Initially I am trying to create perfectly overlapping meshes, with corresponding BCs, but eventually I plan to keep the refined mesh as a subdomain of the coarse main mesh. The ideal scenario is a mix of two reference I describe below - eventually, i would like to solve different equations on the two meshes, and interpolate data between the two.
My question is how do I place the two meshes in the case structure, so as to obtain a good framework to apply meshToMesh/meshToMesh0 for intepolation.
This post talks about mapping between two meshes, and seems closest to what I would like to do, but I cannot understand how the mesh creation and case organization works in this situation:
Map fields every time step
If I create IOobject like this, where does it read the "regionSource". Does this replace the #include "createMesh.H" line in my application?
In meshToMesh, I have source and target Mesh pointers, but I am confused as to where these objects are to located and named.
For the region specific solver part, I suppose I can invoke different codes based on region name, modifying the basic fluid and solid distinction, but interpolation in the chtMultiregionFoam cases have conjugate domains with A-to-B kind of boundaries generated by splitMesh. I am not looking to split the mesh and have these kind of boundaries, but have two polyMeshes.
If anyone has some experience with this, I would really appreciate some rough starting pointers and important tools/possible logical series of steps, as right now I am with a lot of scattered ideas and utterly confused.
mrishi is offline   Reply With Quote
Old   March 5, 2023, 07:24
Xiaobo YAO
hdotyao is on a distinguished road
Hi Rishikesh,
Have you solved this problem cause I am encountering a similar situation?
Best,
Yao
hdotyao is offline   Reply With Quote
interpolation, multiregion meshing
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Simple channel case using cyclicAMI will not converge cbcoutinho OpenFOAM Running, Solving & CFD 3 August 4, 2015 13:28
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 11:13
Trouble with simple AMI case Horus OpenFOAM 0 February 26, 2013 10:31
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
