Multiphase Initial condition for an emulsion
Old   September 24, 2019, 06:29
Lightbulb Multiphase Initial condition for an emulsion
Duncan Weatherhead
duncan21187 is on a distinguished road
Hi OF community!
Hoping for some help with a multiphase case I’m trying to set up of an emulsion of oil/water in a pipe. The intention is to assess where the water will collect once the pipe is in shutdown (i.e no end-end flow) and the emulsion separates.
I was hoping to do this using interFoam, but was wondering if there was a function similar to (or within) setFields that would allow me to randomly distribute the dispersed phase based purely on the phase fraction (10%ish in this case) to give me a realistic initial condition?
Any answers very welcome!
duncan21187 is offline   Reply With Quote
Old   September 30, 2019, 04:44
Andrea
Andrea1984 is on a distinguished road
Maybe you could code something using funkySetFields? Try to have a look at this thread: how to initialize a random velocity field with funkySetFields
Not exactly what you are trying to do but it might give you an idea.
Andrea
Andrea1984 is offline   Reply With Quote
Old   October 2, 2019, 20:33
Kirk Jarvis
kcjarvis56 is on a distinguished road
Consider using multiphaseInterFoam. I would suggest looking at the tutorials and try to develop a simple case to prove the concept you are trying to achieve. There are other multiphase solver that might also work.
kcjarvis56 is offline   Reply With Quote
Old   October 3, 2019, 09:08
Andrea
Why using multiphaseInterFoam if you only have to model two phases, i.e. oil and water? I think interFoam should be enough.
One possible issue I see (depending on how finely dispersed your emulsion is) is that you are probably going to need a very fine mesh in order to resolve the interface between the two phases properly in a VoF approach. Maybe a multifluid solver like twoPhaseEulerFoam might be a computationally cheaper option?
Andrea
Old   October 5, 2019, 09:43
Kirk Jarvis
Attached is a test case that should get you started in the right direction using multiphaseEulerFoam. I understand it could also be done with a two phase solver also. It will run with v1806.
Old   March 22, 2024, 10:33
Sulis
Sulis is on a distinguished road
Hello, I wonder if this is a case of emulsion? I keep getting errors when running it with v2312.Error message indicating that the file could not be found:constant/phaseProperties
Sulis is offline   Reply With Quote
initial condition, interfoam, multiphase mixture, setfields
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
