Need help setting up chtMultiRegion
Old   September 23, 2019, 09:42
Default Need help setting up chtMultiRegion
Oskar T
OskarT is on a distinguished road
I am currently learning how to setup a chtMultiRegion problem but I'm having hard time finding a good tutorial or walkthrough on how to set it up.
I have created an incredible easy heat sink which I wish to flow air through. The air will pickup some heat which will be dissipated from the flange which will have an energy flux assigned into it (I believe this is a boundary condition).
I have: A heat sink (solid) inside a "wind-tunnel" (Inlet, Outlet and walls) blowing air.
The sink has been exported from my CAD-software as an '.stl'-file. I have found tutorials showing how to create the mesh and split the regions (using snappyHexMesh) and managed to do just that.
My commands are as follow:
  • blockMesh
  • snappyHexMesh -overwrite
  • splitMeshRegions -cellZones -overwrite
In my boundary condition (0), system and constant folder I now have three folders; domain1, Heater and Outside.
Now I don't know how to continue setting up the boundary conditions and the rest of the case necessary to run a simulation. Any ideas or guidance is appreciated!
snappyHexMeshDict
|  \\    /   O peration     | Version:  v1906                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
// Which of the steps to run
castellatedMesh true;
snap            false;
addLayers       false;
geometry
	Outside
		type	searchableBox;
		min		(-0.1 -0.05 0.001);
		max 	(0.2  0.07 0.1);
    Heater
        type triSurfaceMesh;
        file "Faces.stl";
castellatedMeshControls
	// Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
		{ file "Faces.eMesh"; level 3; }
    refinementSurfaces
		Outside
			level	(1 1);
			faceZone	Outside;
			cellZone	Outside;
			cellZoneInside	inside;
        Heater
            level	(2 2);
			faceZone	Heater;
			cellZone	Heater;
	resolveFeatureAngle 30;
	    refinementRegions
    locationInMesh (0.05 0.01 0.01); // Offset from (0 0 0) to avoid coinciding with face or edge
	allowFreeStandingZoneFaces true;
	maxLocalCells 1500000;
    maxGlobalCells 2000000;
	minRefinementCells 1;
    nCellsBetweenLevels 3;
// Settings for the snapping.
snapControls
	implicitFeatureSnap true;
	explicitFeatureSnap false;
    nSmoothPatch 3;
    tolerance 2;
    nSolveIter 110;
    nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
    layers
        "Car.*"
            nSurfaceLayers 15;
    relativeSizes       false; // false means you specify the minthickness
    expansionRatio      1.15;
//    finalLayerThickness 1e-2;		// Either final or first + expansionRatio must be specified
    minThickness        1e-3;
    firstLayerThickness 2e-3;
//  maxThicknessToMedialRatio 0.6;
	featureAngle 120;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    minTetQuality -1e+30;
/*writeFlags
//    scalarLevels
    layerSets
    layerFields
mergeTolerance 1e-6;
blockMeshDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale   1;
vertices
    (-0.1 -0.05 -0.001) // 0
    ( 0.2 -0.05 -0.001) // 1
    ( 0.2  0.07 -0.001) // 2
    (-0.1  0.07 -0.001) // 3
    (-0.1 -0.05 0.1) // 4
    ( 0.2 -0.05 0.1) // 5
    ( 0.2  0.07 0.1) // 6
    (-0.1  0.07 0.1) // 7
blocks
    hex (0 1 2 3 4 5 6 7) (30 13 10) simpleGrading (1 1 1)
edges
boundary
    Sym1
        type symmetryPlane;
        faces
            (0 1 5 4)
    Sym2
        type symmetryPlane;
        faces
            (3 7 6 2)
    Inlet
        type patch;
        faces
            (0 4 7 3)
    Outlet
        type patch;
        faces
            (1 2 6 5)
    Ground
        type wall;
        faces
            (0 3 2 1)
    Top
        type symmetryPlane;
        faces
            (7 6 5 4)
STL-file of the heat sink
solid Volume
  facet normal	-4.440892098500626e-19	  -0.001	  3.3306690738754697e-19
    outer loop
      vertex		0.0	  	0.0	  	0.0
      vertex		0.02	  	-8.881784197001253e-18	  	7.771561172376097e-18
      vertex		0.02	  	-3.731384267595481e-18	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		-8.584000447031584e-18	  	5.150399929405771e-18	  	0.015463560104370118
      vertex		0.0	  	0.0	  	0.0
    endloop
  endfacet
  facet normal	0.0	  0.0	  0.001
    outer loop
      vertex		-7.843851199259514e-18	  	0.003333333253860474	  	0.015463560104370118
    endloop
  endfacet
  facet normal	-0.0	  0.0	  0.001
    outer loop
      vertex		0.02	  	0.003333333253860474	  	0.015463560104370118
    endloop
  endfacet
  facet normal	0.0	  0.001	  -0.0
    outer loop
      vertex		-9.251858185612576e-19	  	0.003333333253860474	  	0.003
    endloop
  endfacet
  facet normal	0.0	  0.001	  0.0
    outer loop
      vertex		0.02	  	0.003333333253860474	  	0.003
    endloop
  endfacet
    outer loop
      vertex		1.850371663592295e-19	  	0.008333333015441894	  	0.003
    endloop
  endfacet
    outer loop
      vertex		0.02	  	0.008333333015441894	  	0.003
    endloop
  endfacet
  facet normal	0.0	  -0.001	  0.0
    outer loop
      vertex		0.02	  	0.008333333015441894	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		-6.733628598150831e-18	  	0.008333333015441894	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		0.02	  	0.011666666984558106	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		-5.9934797738952354e-18	  	0.011666666984558106	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		9.251858185612576e-19	  	0.011666666984558106	  	0.003
    endloop
  endfacet
    outer loop
      vertex		0.02	  	0.011666666984558106	  	0.003
    endloop
  endfacet
    outer loop
      vertex		0.02	  	0.01666666603088379	  	0.003
    endloop
  endfacet
    outer loop
      vertex		2.0354089490655326e-18	  	0.01666666603088379	  	0.003
    endloop
  endfacet
    outer loop
      vertex		0.02	  	0.01666666603088379	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		-4.8832567492700795e-18	  	0.01666666603088379	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		-4.143107925014484e-18	  	0.02	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		0.02	  	0.02	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		4.440892098500626e-18	  	0.02	  	-1.1102230246251566e-17
    endloop
  endfacet
    outer loop
      vertex		0.02	  	0.02	  	-3.3306690738754695e-18
    endloop
  endfacet
  facet normal	3.885780586188048e-19	  -5.551115123125783e-19	  -0.001
    outer loop
      vertex		0.0	  	0.0	  	0.0
    endloop
  endfacet
    outer loop
      vertex		0.0	  	0.0	  	0.0
    endloop
  endfacet
  facet normal	-0.001	  0.0	  -7.771560642980504e-19
    outer loop
      vertex		-2.331468351712829e-18	  	0.01666666603088379	  	0.003
      vertex		-1.2017600117624449e-17	  	0.01666666603088379	  	0.015463560104370118
      vertex		-1.2017600117624449e-17	  	0.02	  	0.015463560104370118
    endloop
  endfacet
  facet normal	-0.001	  6.57312606368018e-26	  -7.771560642980504e-19
    outer loop
      vertex		6.162975822039155e-33	  	0.02	  	-1.5543122344752193e-17
    endloop
  endfacet
  facet normal	-0.001	  0.0	  -7.771561172376096e-19
    outer loop
      vertex		-2.331468351712829e-18	  	0.011666666984558106	  	0.003
    endloop
  endfacet
    outer loop
      vertex		-2.331468351712829e-18	  	0.008333333015441894	  	0.003
      vertex		-1.2017600117624449e-17	  	0.008333333015441894	  	0.015463560104370118
      vertex		-1.2017600117624449e-17	  	0.011666666984558106	  	0.015463560104370118
    endloop
  endfacet
    outer loop
    endloop
  endfacet
    outer loop
      vertex		-2.331468351712829e-18	  	0.003333333253860474	  	0.003
      vertex		-1.2017600117624449e-17	  	1.7168000470546694e-18	  	0.015463560104370118
      vertex		-1.2017600117624449e-17	  	0.003333333253860474	  	0.015463560104370118
    endloop
  endfacet
    outer loop
      vertex		0.0	  	0.0	  	0.0
    endloop
  endfacet
    outer loop
      vertex		0.0	  	0.0	  	0.0
    endloop
  endfacet
  facet normal	-0.001	  -2.9582283945787943e-34	  -7.771561172376096e-19
    outer loop
      vertex		0.0	  	0.0	  	0.0
    endloop
  endfacet
  facet normal	-0.001	  -6.573127325857629e-26	  -7.771560642980504e-19
    outer loop
      vertex		0.0	  	0.0	  	0.0
    endloop
  endfacet
  facet normal	0.001	  -0.0	  0.0
    outer loop
    endloop
  endfacet
  facet normal	0.001	  0.0	  0.0
    outer loop
      vertex		0.02	  	0.02	  	-7.771561172376097e-18
    endloop
  endfacet
    outer loop
    endloop
  endfacet
    outer loop
    endloop
  endfacet
    outer loop
    endloop
  endfacet
    outer loop
      vertex		0.02	  	-7.164983938188346e-18	  	0.015463560104370118
    endloop
  endfacet
    outer loop
    endloop
  endfacet
    outer loop
    endloop
  endfacet
    outer loop
    endloop
  endfacet
    outer loop
    endloop
  endfacet
endsolid Volume
OskarT is offline   Reply With Quote
Old   September 25, 2019, 16:51
clapointe is on a distinguished road
There are many cht tutorials distributed with OpenFOAM : https://github.com/OpenFOAM/OpenFOAM...ultiRegionFoam. I've not looked at them, but snappyMultiRegionHeater sounds like it'd be helpful.
Caelan
clapointe is offline   Reply With Quote
cht, heat transfer, multi region, snappyhexmesh
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
