[groovyBC]Insert a groovyBC for gas inlet at a water column |
August 30, 2019, 16:30 |
Felipe Chagas
Rep Power: 7 |
Hello guys, how are you?
So, I'm trying to simulate an ascendent air-water two-phase flow, such as presented in Figure 1. This study is based in a real experiment, which consists on a 100 meter tube (represented by the red color text) filled with water at rest, opened to atmosphere at the top, and gas is injected at the bottom of the tube . Due to processing limitation and for my study purposes, I'm just interested in what happens at the first 10 meters of the column, as presented in the figure. I am using interIsoFoam and interFoam in OF5.X to make the study, for inicial simplifications for the second, and future implementation for the first. However, the gas velocity at the inletgas BC must be a groovyBC. Explaining the equation present at figure 1: K, H, μg, dres, de, are constant values. Pformacao its the pressure that comes from the equipment and is a constant value. Pfundo must be the pressure in front of the inletgas patch, so it depends on the each timestep pressure at the patch. So, gas inflow velocity (vg_e) at the domain depends on the pressure (Pfundo) exerted in front of the inlet patch. And the pressure, at the bottom of the domain depends on how much gas has entered the domain... I've tried to insert this groovyBC at OF, considering the p internalField in groovyBC, but I'm not sure how I must insert it right way: > Courant is going to high; > timestep continuityerrors too; > Velocity residuals are low; I will attach my U, P and log files, so you can see what I'm doing wrong... Please, this is really important to me, to finish my dissertation... Thank you very much for your time. Best regards! |
Free turbulent water jet into liquid metal pool, inlet submerged | Estone | Fluent Multiphase | 1 | February 22, 2019 13:39 |
[swak4Foam] Inlet Boundary with groovyBC | fmerk | OpenFOAM Community Contributions | 0 | May 3, 2017 10:00 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 19, 2014 23:42 |
INLET BOUNDARY FOR BUBBLE COLUMN | Swarnendu | CFX | 1 | July 5, 2004 02:16 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
