Initial conditions genereated by setWave utility ain't consistent with analitical one |
August 29, 2019, 14:45 |
ChengzhaoZhang
Rep Power: 7 |
hi everyone,
recently i have found that the initial wave date for the velocity generated by setWave are not consistent with the theoretical solutions. the tutorial case is the standard case which links to openfoam6/tutorials/multiphase/interFoam/laminar/wave. When I output the velocity profiles through vertically the location of L/4(L=wavelength). I found that there is a turning point at the area near the bottom boundary in the velocity profile of horizontal velocity component, which is shown in the image. In principle, this velocity profiles should be matching with the velocity profile of airy wave theory. However, it shows this turning point when we initialize the wave data. We can see there is a turning point on the vertical velocity component near the region of the bottom boundary. I have tested many cases, the turning point always exists. Does anyone know how to improve this? that would be very helpful. thanks |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
