How Prandtl number is dependent on Pressure?
Old   August 13, 2019, 08:33
Default How Prandtl number is dependent on Pressure?
Raza Javed
Raza Javed is on a distinguished road
Hello Everyone,
I have a question related to the dependency of prandtl number on Pressure.
Air has a Prandtl number of 0.7 at atmospheric pressure.
If I want to lower the pressure of my fluid(air in my case) from atmospheric pressure then how can I find the new Prandtl number for this new pressure?
I know from the relation, that Prandtl number is not directly dependent on Pressure and it depends on thermal conductivity, specific heat and viscosity.
As I am changing the pressure, so I need to know how the Prandtl number will change?
Any help would be highly appreciated.
Thank you
Raza Javed is offline   Reply With Quote
Old   June 23, 2020, 09:52
geth03 is on a distinguished road
of course the prandtl number is dependant of pressure.
for your fluid in interest you need to check how thermal conductivity, specific heat and viscosity change with regards to pressure and then figure it out
somehow.
https://www.researchgate.net/figure/...fig4_269800776
here you can see that thermal conductivity of water/steam increases with increasing pressure.
https://www.researchgate.net/figure/...fig2_269800776
here you can see that specific heat capacity of water/steam decreases with increasing pressure.
assuming a constant dynamic viscosity for example, because prandtl number is proportional to specific heat capacity to thermal conductivity ratio, an increase in pressure would mean a decrease in the prandtl number, assuming isothermal change, for the above shown water/steam.
geth03 is offline   Reply With Quote
openfoam, prandtl number
[Other] Equal decomposition of cylindrical fluid domain Sean95 OpenFOAM Meshing & Mesh Conversion 3 February 12, 2019 04:34
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
