Droplet evaporation - VOF - icoReactingMultiphaseInterFoam |
August 7, 2019, 15:53 |
Jagan Jothimani
I am using icoReactingMultiphaseInterFoam solver for simulating water droplet evaporation, I have got everything working but when i try to visualize using paraview i find that water droplet keeps on moving over the entire surface, is there a specific thing i need to specify to keep it stable. If i change the mu value in thermophysicalproperties.liquid to that of mercury, it doesn´t move. I am using velocity of 0.1 m/s, with a rectangular chamber of 4(width)x2(height)x10(length) cm dimensions and droplet is placed at a distance of 2 cm from inlet and is of 50microL size. Is there anything i could do to fix this, i tried RAS with nutRoughwall function still i couldn't figure it out. Any help is appreciated, thanks in advance. I am attaching geometry cross section for your refernce. |
March 19, 2020, 05:25 |
Wenjun Tuan
Rep Power: 8 |
Hi Jagan,
I am now also using this solver for the simulation of droplet evaporation. Could you tell me what boundary condition you are using? I could not get the explainable results. Look forward to your kind reply. Best regards, wenjuny |
July 17, 2020, 02:51 |
Naveen
Rep Power: 10 |
check contact angle
June 29, 2021, 16:35 |
Ejaz Ahmed
Rep Power: 5 |
The reason maybe the spurious current associated with VOF due to error associated with curvature calculation of the droplet which you can't eliminate completely. Can you share your case so that I can have a look at your parameters?
2D VOF Droplet evaporation model. Multi-component problem | nb92 | Fluent Multiphase | 0 | February 28, 2014 11:36 |
droplet falling - VOF | bohis | FLUENT | 1 | July 10, 2013 05:28 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 21:47 |
Help! Using VOF to solve droplet heat tranfer | LMJay | FLUENT | 0 | December 5, 2007 20:20 |
DPM Modelling: Colloid droplet evaporation | Meng Wai Woo | FLUENT | 1 | August 1, 2007 01:27 |
