How to define Vacuum Conditions in OpenFoam
Old   August 26, 2019, 06:46
Raza Javed
Raza Javed is on a distinguished road
Originally Posted by simrego View Post
I think you see some conduction through the air.
This is the output of
wallHeatFlux -region air -latestTime
Wall heat fluxes [W]
airTop
    convective: 0
    radiative:  5.796363e-07
    total:      5.796363e-07
airLeft
    convective: 0
    radiative:  6.173778e-07
    total:      6.173778e-07
airRight
    convective: 0
    radiative:  6.460372e-07
    total:      6.460372e-07
airBack
    convective: 0
    radiative:  -3.128043e-06
    total:      -3.128043e-06
airBottom
    convective: 0
    radiative:  6.3663e-07
    total:      6.3663e-07
air_to_heater
    convective: 3.336472e-05
    radiative:  6.121647e-07
    total:      3.397688e-05
Raza Javed is offline   Reply With Quote
Old   August 26, 2019, 07:13
anonymous
simrego is on a distinguished road
Yes but your air is steady(all zero velocity), so it is a conduction not a convection (It is like your air is a solid medium). This is why I think your material props are not correct for vacuum. This "concective" flux should be really small, close to zero since there is no media to convect (or conduct) the heat.
simrego is offline   Reply With Quote
Old   August 26, 2019, 07:26
Raza Javed
I think it is writing convection because in the region properties we declared Air as a Fluid, and normally convection occurs between solid and a fluid.
Now, we can be sure that our radiation is working?
Below are the results for the same case but without radiation:
airTop
    convective: 0
    radiative:  -0
    total:      0
airLeft
    convective: 0
    radiative:  -0
    total:      0
airRight
    convective: 0
    radiative:  -0
    total:      0
airBack
    convective: 0
    radiative:  -0
    total:      0
airBottom
    convective: 0
    radiative:  -0
    total:      0
air_to_heater
    convective: 3.341257e-05
    radiative:  -0
    total:      3.341257e-05
End
Old   August 26, 2019, 08:23
anonymous
It seems like it's working
I told you to run in both cases because in earlier (i think you are using a never version) versions it only wrote the sum flux (rad+conv)
Old   August 26, 2019, 08:33
Raza Javed
Yes I RUN both cases, and I posted here the results of both (with and without radiations).
In with radiation, it is showing radiation on every boundary.
In withour radiation, it is showing only convection only on air to heater boundary.
Old   August 26, 2019, 08:38
anonymous
I know u did in both cases, I just told you why I gave you this advice.
Old   August 26, 2019, 08:46
Raza Javed
Oh I see.
But I must say, you really helped a lot. I really appreciate this.
Thank you so much for your prompt replies.
I might ask you again, if I have some doubt.
Thank you once again..
Old   September 1, 2019, 15:01
Raza Javed
Sorry to disturb you again.
In my geometry, I am putting fvOptions in the heater region, the volume of my region is 0.000125m3. And the power I am putting is 1W. So I am using specific mode in fvOptions and I am putting the value 1W/0.000125m3=8000.
My fvOptions is given below:
heatSource
    type            scalarSemiImplicitSource;
    active          true;
    selectionMode   all;
    scalarSemiImplicitSourceCoeffs
        selectionMode   all;
        volumeMode      specific;//absolute;
        injectionRateSuSp
            h           (8000 0);
Now, to check what should be the temperature of my heater region, can I use boltzman law of radiation like below?
P = e*sigma*A*(T)^4
Old   May 9, 2022, 13:38
Default thermophysical properties of vaccum
  #49
Patrick Saft
$Chaos is on a distinguished road
Hello togther,
Raza, i have a similiar problem as you. I also have to calculated vaccum.
How do you finally realised it?
which thermophysical properties have you taken?
thank you
kind regards
$Chaos is offline   Reply With Quote
openfoam, radiation, vacuum
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
An odd ERROR mdakbari Fluent UDF and Scheme Programming 7 April 4, 2016 05:30
OpenFoam volume conditions vmsandip2011 OpenFOAM Running, Solving & CFD 5 February 24, 2012 11:32
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
