August 13, 2019, 07:21 |
#21 |
anonymous
Rep Power: 14 |
Okay so to clarify. You have a closed domain, so you must define a pressure somewhere. This is what you are doing in the fvSolution file. for the cell with id 0, you define a pressure with 2.5 pascal.
In the p_rgh file what you are setting in your case are only initial values. Also for p. Since you set the pressure to 2.5 pascal in that cell in your domain, you can assume that the pressure will be ~2.5 pascal in the whole domain. That's why it is suggested (not a must, but strongly suggested) to initialize p_rgh and p with that 2.5 pascal to help the convergence of the solver. |
August 13, 2019, 07:25 |
#22 | |
anonymous
Rep Power: 14 |
Pr is not directly, but it is calculated from the conductivity, viscosity, and specific heat. And they can depend. I'm not 100% if the Pr of air in that really small pressure is the same than on atmospheric pressure. You have to check it before you get unreal results because of that really simple mistake (wrong material props). |
August 13, 2019, 07:29 |
#23 | |
Raza Javed
Rep Power: 7 |
If I understood right, this is what I did: fvSolutions: Code:
solvers { rho { solver PCG preconditioner DIC; tolerance 1e-7; relTol 0; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 10; } "(U|h|k|epsilon)" { solver PBiCG; preconditioner DILU; tolerance 1e-7; relTol 0.1; } } SIMPLE { momentumPredictor on; nNonOrthogonalCorrectors 2; pRefCell 0; pRefValue 2.5; //rhoMin rhoMin [1 -3 0 0 0] 700; //rhoMax rhoMax [1 -3 0 0 0] 1200; } relaxationFactors { fields { rho 1; p_rgh 0.7; } equations { U 0.7; h 0.7; nuTilda 0.7; k 0.7; epsilon 0.7; omega 0.7; "ILambda.*" 0.7; } } // ************************************************************************* // and changeDictionaryDict: Code:
p_rgh { internalField uniform 2.5; boundaryField { defaultFaces { type fixedFluxPressure; value uniform 2.5; } ".*" { type fixedFluxPressure; value uniform 2.5; } } } p { internalField uniform 2.5; boundaryField { ".*" { type calculated; value uniform 2.5; } } } I hope this is correct now? |
August 13, 2019, 08:13 |
#24 |
anonymous
Rep Power: 14 |
Yep, seems fine.
August 20, 2019, 05:53 |
#25 |
Raza Javed
Rep Power: 7 |
Hi..
Hope you will be fine. I have question related to fvOptions. If I am using fvOptions to put power in one volume, then what exactly this power is? Is this a power dissipation of that object? And how can I calculate that with this power, what would be the temperature of my object? Thank you |
August 23, 2019, 05:42 |
#26 | |
Raza Javed
Rep Power: 7 |
Hello, I have one question here: How can I find the referenceCell to put in the fvOptions? for example, in my case, I want to have 1e-5 pascal pressure on the complete AIR domain. so how can I put that? I shall be very thankful if you can help. Thank you |
August 23, 2019, 06:02 |
#27 |
anonymous
Rep Power: 14 |
Hi!
If you solve the flow equations, you cant. But as i mentioned earlier you can use frozenFlow in your fvSolution of air and you won't solve any flow equations. Just initialize the domain with that 1e-5 pascal, and zero velocity, and that's all. It won't change since you won't solve any flow equations, only the energy equation. |
August 23, 2019, 06:20 |
#28 | |
Raza Javed
Rep Power: 7 |
Thank you so much for your reply. Yes. I did that frozen flow, and Now the solver is not solving any flow equation. Good. Now, I reduced the pressure to a very low value for Air, to generate a vacuum. But the results after this remain exactly the same. There is no difference in the temperature gradient as with the high temperature (1 bar). I checked for the prandtl number also, and It doesn't actually change so much with the pressure (its range is approximately 0.7 to 0.8). But I don't know, how the behavior of temperature could be same even with so less pressure? Thank you |
August 23, 2019, 06:39 |
#29 |
anonymous
Rep Power: 14 |
Of course they remain the same with lower pressure. Check the energy equation what you are solving. It is not affected by the pressure.
BUT since you decrease the pressure your material props must change I think, since you have much less air particles. The thermal conductivity of the air will decreasing really fast as you decrease the pressure. In a really high vacuum you will have nearly 0 thermal conductivity. Maybe it is not significant from 1bar to 10. But when you go down from 1 bar to 1e-5 Pa, it should be. |
August 23, 2019, 07:27 |
#30 | |
Raza Javed
Rep Power: 7 |
Thank you so much for your response. It is helpful. One more question here, Is it possible to use P1 model for Air in my case? I tried P1 model and it is showing that the Air gets hot faster as compared to the case if I don't use radiation. I think this behaviour is correct? or NOT? Thank you |
August 23, 2019, 08:27 |
#31 |
anonymous
Rep Power: 14 |
Not really. P1 is good for optically thick media. For air it is not.
It became hot faster because i think you had wrong coefficients for your absorption emission model and the air is absorbed a lot of heat which is not correct since air is "transparent". The radiation should just go through the air without absorption/emission... That's why viewFactor model is the best choice for you I think. |
August 23, 2019, 11:13 |
#32 | |
Raza Javed
Rep Power: 7 |
Because I don’t know what I should see to make it sure that my radiation is working fine.? Thank you. |
August 26, 2019, 04:52 |
#33 | |
Raza Javed
Rep Power: 7 |
I have read in forum that If I want to check that my radiation model is working or NOT, then I must use wallHeatFlux utility on each boundary. but I don't know about that. Can you please help me in this? Thank you |
August 26, 2019, 05:11 |
#34 |
anonymous
Rep Power: 14 |
Yes, this is a good idea
run this (I hope i have no typo, and replace the regionName and numberOfProcessors to your needs): chtMultiRegionSimpleFoam -postProcess -func wallHeatFlux -region regionName -latestTime or in parallel: mpirun -np numberOfProcessors chtMultiRegionSimpleFoam -parallel -postProcess -func wallHeatFlux -region regionName -latestTime But you have to run it in on the case with and without radiation so you can see the difference. |
August 26, 2019, 05:15 |
#35 | ||
Raza Javed
Rep Power: 7 |
DO I need to install anything or configure any library etc before doing this? OR I can directly do this? Quote:
August 26, 2019, 05:17 |
#36 | |
Raza Javed
Rep Power: 7 |
because some people are saying that something should be added in controlDict in functions etc etc. but I didn't use it, so I don't have any idea. |
August 26, 2019, 05:24 |
#37 |
Raza Javed
Rep Power: 7 |
I RAN it and it gave me the following error:
Create time Create fluid mesh for region air for time = 28.5 Create solid mesh for region heater for time = 28.5 --> FOAM Warning : From function static bool Foam::functionObjectList::readFunctionObject(const Foam::string&, Foam::dictionary&, Foam::HashSet<>&, const Foam::word&) in file db/functionObjects/functionObjectList/functionObjectList.C at line 245 Cannot find functionObject file wallHeatFlux Time = 28.5 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type laminar Selecting radiationModel viewFactor Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Selecting sootModel none Adding MRF No MRF models present Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region heater Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel opaqueSolid Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Selecting sootModel none Adding fvOptions No finite volume options present End |
August 26, 2019, 05:43 |
#38 |
anonymous
Rep Power: 14 |
What version of OF are you using?
You don't need anything for that. It should works: You can also do it in the controlDict file like this (but this is the same function call): https://openfoam.com/documentation/g...x.html#details |
August 26, 2019, 05:53 |
#39 | |
Raza Javed
Rep Power: 7 |
I did the following: In the controlDict I put: Code:
functions { #include wallHeatFlux(region=air) } Code:
wallHeatFlux -region air -latestTime And it Works But on the air_to_heater interface, it is also showing some convection also. even After I am using frozenFlow=Yes Thank you |
August 26, 2019, 06:23 |
#40 |
anonymous
Rep Power: 14 |
I think you see some conduction through the air.
openfoam, radiation, vacuum |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
An odd ERROR | mdakbari | Fluent UDF and Scheme Programming | 7 | April 4, 2016 05:30 |
OpenFoam volume conditions | vmsandip2011 | OpenFOAM Running, Solving & CFD | 5 | February 24, 2012 11:32 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
