Creating outlet in a wall type boundary
Old   July 30, 2019, 13:18
Default Creating outlet in a wall type boundary
Owais Shabbir
Owais Shabbir is on a distinguished road
I want to make my 'outlet' into a wall and create an box shaped outlet through the original outlet of my blockMesh but I am not sure where to start this from. I am new with OF6 and CFD and i got confused when I tried approaching the utilities
I looked at createPatch and createBaffles.
The description says the it creates a set out of faces, but will I not need cells instead of faces from the origianl outlet to become and small outlets?
I am attachning pictures so its more clear.
I have an outlet and I want to convert it to a wall and make smaller outlets out of it as shown in the second picture.
my blockMeshDict looks like this:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (-0.03 -0.005 -0.18)
    (0.7 -0.005 -0.18)
    (0.7 0.57 -0.18)
    (-0.03 0.57 -0.18)
    (-0.03 -0.005  0.0169)
    (0.7 -0.005  0.0169)
    (0.7 0.57  0.0169)
    (-0.03 0.57  0.0169)
blocks
hex (0 1 2 3 4 5 6 7) (60 60 40) simpleGrading (1 1 1)
edges
boundary
    walls
        type wall;
        faces
            (3 7 6 2)
   (1 5 4 0)
   (0 3 2 1)
   (4 5 6 7)
    inlet
        type patch;
        faces
            (0 4 7 3)
    outlet
        type patch;
        faces
            (2 6 5 1)
mergePatchPairs
Thanks
OS
Owais Shabbir is offline   Reply With Quote
Old   July 30, 2019, 19:03
clapointe is on a distinguished road
Yes, you can do this with createPatch. First, make the "outlet" patch in your blockMeshDict type wall. Then, use topoSet to select a faceSet of cell faces on the old "outlet" patch (now a wall) and createPatch to make a patch from this faceSet. The fireFoam tutorial smallPoolFire3D is a good example of this.
Caelan
clapointe is offline   Reply With Quote
Old   July 31, 2019, 04:11
Owais Shabbir
Hi Clapointe,
Thanks for a quick answer.
Will this affect later, if I have to import a .stl file in my domain?
Best Regard,
OS
Old   July 31, 2019, 10:41
Import how? Like with snappyHexMesh? If so, it should be fine.
Caelan
Old   July 31, 2019, 10:44
Thumbs up Update:
Owais Shabbir
Quick update:
the patches worked beautifully.
Yes i meant through via snappyHexMesh.
Thanks for you help Caelan.
BR
Owais
createbaffles, createpatchdict, making holes
rSF: p divergence in combustor (wt negative value) zonda OpenFOAM Pre-Processing 4 April 10, 2018 07:59
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
