Help with setting up BC for Pressure in stirred tank multiphase simulation
Old   July 18, 2019, 08:02
Default Help with setting up BC for Pressure in stirred tank multiphase simulation
Mazen Draw
MazenDraw is on a distinguished road
Hello Foamers!
I am trying to run a multiphase simulation using reactingTwoPhaseEulerFoam solver in a stirred tank. For now I sat the rotation velocity of the rotating zones to 0. I have used setFields to fill 75% of the tank with water and 25% with air (check the attachments), because I do not want the water to escape through the outlet in the top. I sat the flow for both water and air to laminar. Turned off all the bubble forces and switched my air inlet with a wall. All of this just to simplify as much as possible and narrow down where the problem is.
I noticed that when I change the gravity acc. value and make it very small (e.g -9.81e-2), the solver would continue to work. If I set it to the normal value -9.81, the min/max values of air volume fraction get very big, and the solver stops. So I figured it is probably a problem with the BC of pressure, since it is directly related to the gravity acc.
There are two files for the pressure in 0 folder. One is p and the other is p_rgh. From what I understood, p is the total pressure and p_rgh is the total pressure minus the hydrostatic pressure. Please correct me if I am wrong!
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    walls
        type               calculated;
        value              $internalField;
    outlet
        type               calculated;
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
boundaryField
    walls
        type            fixedFluxPressure;
        gradient        uniform 0;
        value           uniform 0;
    outlet
        type               prghPressure;
        p                  $internalField;
I want my outlet to act like an atmospheric opening. So is this the right setting? What could be causing the solver to stop in this way?
Since U.air and U.water might be related to this issue, here they are:
U.air:
    walls
        type            slip;
    outlet
         type            pressureInletOutletVelocity;
         phi             phi.air;
U.water:
    walls
        type            noSlip;
    outlet
        phi                phi.water;
The error if it is of any interest:
PIMPLE: Iteration 20
MULES: Solving for alpha.air
alpha.air volume fraction = 6.28261e+52  Min(alpha1) = -1.91281e+66  Max(alpha1) = 2.43384e+66
Constructing face momentum equations
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/usr/lib64/libc.so.6"
#3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) at ??:?
#4  Foam::DICPreconditioner::DICPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#5  Foam::lduMatrix::preconditioner::addsymMatrixConstructorToTable<Foam::DICPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#6  Foam::lduMatrix::preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#7  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#9  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#10  Foam::fvMatrix<double>::solve() at ??:?
#11  ? at ??:?
#12  __libc_start_main in "/usr/lib64/libc.so.6"
#13  ? at ??:?
Floating point exception
MazenDraw is offline   Reply With Quote
Old   June 5, 2021, 04:52
harshawardhank
harsha_kulkarni is on a distinguished road
Check your Boundary conditions
harsha_kulkarni is offline   Reply With Quote
boundary condition, multiphase, pressure
ANSYS Fluent Sloshing in baffled tank simulation Fisya CFD Freelancers 2 August 27, 2019 18:55
Translation motion not working correctly in Eulerian Multiphase simulation (V.11_02) Mikel Valderrama STAR-CCM+ 2 May 13, 2019 07:33
CFD Simulation of Stirred tank varun loomba Main CFD Forum 1 September 18, 2013 07:04
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 10:32
Simulation of stirred tank using sliding mesh technique aymneng Main CFD Forum 0 March 3, 2012 13:19
