Deal with Y+ on propeller with std wall function |
June 27, 2019, 13:12 |
Rep Power: 9 |
I have been following the forum for a long time and today here is my first post. I am a graduate in biology and am learning the cfd by myself. My question is about modeling a stirred tank with pitched blade turbine (RAS with standard wall function). I performed a grid sensitivity study on 3 meshes (200, 400 and 800 K cells) and found that the error increase on the last. When I checked Y+ I found low values (average 10 and minimum less than one). I change SHM settings to get a coarser mesh (500K) and get acceptable Y+ values, but under 30 in upper part of the tank and in part of blades near hub where velocity is low (see attachments 500K and Y+). In order to go further I performed a finer mesh (800 K) but without refinement of the stirrer to increase Y+ on it. But the snapping is now not satisfying (see attachment). Then, I was wondering : - If I have part with low Y+ in region of low velocity what is the impact on results accuracy? Is the 500K mesh good enough ? - How to refine a mesh while keeping Y+ high enough for wall function treatment ? Thanks for your help. |
June 29, 2019, 14:18 |
Rep Power: 9 |
Hello, I continued my research in the forum and it seems that it is difficult to get a y+ on the whole wall in complex geometries.
I am not familiar with the underlying physics and have difficulty evaluating the impact of a first layer in the buffer layer where velocities are low, on the overall flow, while there is a large difference in velocity in the tank. I am not interested in the boundary layer or heat transfer but only in the overall flow and mixing time. In this blog https://www.computationalfluiddynami...oundary-layer/ it is recommended to use scalable / enhanced wall treatment in my case but it is not available in openFoam. I will try to optimize my mesh and refinements and redo grid sensitivity studies. |
y+ wall function stirrer |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 12:55 |
Wall Function | aja1345 | FLUENT | 0 | May 27, 2015 12:01 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Wall function in adverse pressure gradients | stephane baralon | Main CFD Forum | 11 | September 2, 1999 05:05 |
