Cannot find patchField entry
Old   June 27, 2019, 13:09
Default Cannot find patchField entry
Nicoḷ
gnicchelibero is on a distinguished road
Hi everybody
during a mesh creation with openfoam I found this error
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for Inlet
file: /home/gnicche/Scrivania/cilindro/0/p.boundaryField from line 25 to line 51.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /mnt/home/SW/CFDSupportFOAM4.0/beta/OpenFOAM-dev/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191.
FOAM exiting
and this is the file to which it refers:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
object
type zeroGradient;
walls
type slip;
outlet
type fixedValue;
value uniform 0;
Front
type empty;
Back
type empty;
can someone help me? I checked the file again but I don't see any errors
Thanks
gnicchelibero is offline   Reply With Quote
Old   July 2, 2019, 14:02
Yousef
ykanani is on a distinguished road
Originally Posted by gnicchelibero View Post
Hi everybody
Thanks
Use capital I in your p file for Inlet:
inlet ---> Inlet
Regards
ykanani is offline   Reply With Quote
Old   July 8, 2019, 13:08
Nicoḷ
Thank You very much
Regards
Old   September 27, 2021, 05:55
王杰
wangjie is on a distinguished road
Thank You very much
Regards
I have the same problems as you focused on , could you please tell me how did you solve it ? thank you.
wangjie is offline   Reply With Quote
Cannot find patchField entry for InletWall range_rover OpenFOAM Running, Solving & CFD 5 November 18, 2020 22:21
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 hconel OpenFOAM Pre-Processing 0 October 5, 2018 18:22
decomposePar fails "Cannot find patchField entry for maxY" JasonQuinn OpenFOAM Pre-Processing 2 April 4, 2017 02:07
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
