Initializing inlet velocity for a wedged mesh?
Old   June 27, 2019, 11:55
Default Initializing inlet velocity for a wedged mesh?
anu
anu.raghun is on a distinguished road
Hi everyone! I'm trying to simulate laminar flow over a delta wing, and have been running into some problems.
I wanted an inlet velocity parallel to the z axis, so it would flow over the delta wing parallel to its symmetric axis. However, the velocity in paraView appears to be flowing along the x axis. Could someone help me with this?
I've attached a drawing to give you a sense of what I want.
Here is my blockMeshDict:
convertToMeters 0.1;
vertices
(0 0 0) //0
(-0.5 0 -2) //1
(0.5 0 -2) //2
(0 -2 0) //3
(-0.5 -2 -2) //4
(0.5 -2 -2) //5
blocks
hex (0 1 2 0 3 4 5 3) (50 1 200) simpleGrading (0.2 1 1)
edges
boundary
axis
type empty;
faces
(0 3 3 0)
plate
type plate;
faces
(3 4 5 3)
outlet
type patch;
faces
(4 1 2 5)
inlet1
type patch;
faces
(3 0 2 5)
top
type symmetry;
faces
(0 1 2 0)
inlet2
type patch;
faces
(1 4 3 0)
mergePatchPairs
and my U file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
axis
type empty;
outlet
type zeroGradient;
inlet1
type fixedValue;
value uniform (0 0 -0.1);
inlet2
type fixedValue;
plate
type fixedValue;
value uniform (0 0 0);
top
type symmetry;
I'd appreciate any help!
anu.raghun is offline   Reply With Quote
Old   June 28, 2019, 06:18
Zander Meiring
yambanshee is on a distinguished road
For your internal field (all mesh that isn't boundary) is set to 0 in all directions. If you want to initilize your flow, you can set your internal field to have some velocity in the z direction, ie:
internalField uniform (0 0 0.1)
yambanshee is offline   Reply With Quote
Old   June 28, 2019, 12:14
anu
Hi, thanks for replying
I tried changing it and it doesn't seem to have made a difference? Does it have to do with the coordinate system I'm using?
inlet velocity, velocity angle, wedge block
velocity inlet, overset mesh: acceleration JohnAB STAR-CCM+ 17 April 3, 2014 13:54
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
