Residuals written multiple times in file with chtMultiRegion
Old   May 28, 2019, 13:40
Default Residuals written multiple times in file with chtMultiRegion
Luca
marluc is on a distinguished road
Dear All,
I am facing a problem when using the functionObject residuals with chtMultiRegionSimpleFoam.
Here the code:
residualsFluid
      type            residuals;
      libs            ("libutilityFunctionObjects.so");
      writeControl    timeStep;
      writeInterval   1;
      region          fluid;
      fields (p_rgh U h k omega);
The residuals are correctly saved in the corresponding file in the directory postProcessing but they are written three times for every timeStep:
# Residuals
# Time          p_rgh           Ux              Uy              Uz              h               k               omega
1.002           1.0000000e+00   0.0000000e+00   0.0000000e+00   1.0000000e+00   1.0000000e+00   1.0000000e+00   5.7152730e-03
Does anyone know the reason for this?
Thank you in advance.
Luca
EDIT:
I am using OF 5.x and the problem happens in serial as well as in parallel. Residuals are always written three times each.
marluc is offline   Reply With Quote
Old   May 29, 2019, 13:07
Peter Hess
peterhess is on a distinguished road
Hello!
is it possible that you have:
nNonOrthogonalCorrectors 3;
Regards
Peter
peterhess is offline   Reply With Quote
Old   May 29, 2019, 13:10
Luca
Originally Posted by peterhess View Post
Hello!
Regards
Peter
actually not. It is set to 1.
Regards,
Luca
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
