wrong token type - expected word, found on line 80 the punctuation token '('
Old   May 17, 2019, 12:01
Default wrong token type - expected word, found on line 80 the punctuation token '('
Sri harsha Revu
hasha is on a distinguished road
I am trying to create 2 blocks in a wedge of 5 deg, wedge radius of 7 mm and width of 5 mm. I have written my blockMeshDict when i am running this in openFoam 6 i am getting an error like this
wrong token type - expected word, found on line 80 the punctuation token '(' .
I have attached my blockMeshDict zip file, please help me i got stuck with this from a week.
I have 2 questions to you guys
1. Do the trailing spaces in blockMeshDict file causes any problem?
2. How should i define a interface boundary condition in case of multiple blocks?
Thanks a lot.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     6.0;
    format      binary;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
w_rmin 0;    // In y direction
w_rmax 7;
n_rmin 0;
n_rmax 0.3;
xmin 0;
xmax 5;
theta 5;
//delta_x 6E-3;
//delta_y 6E-3;
//xcells #calc "($xmax-$xmin)/$delta_x";
//n_ycells #calc "($n_rmax-$n_rmin)/$delta_y";
//w_ycells #calc "($w_rmax-$w_rmin)/$delta_y";
vertices
    //Block 0
    (0 0 0)                                        //0
    (0 #calc "$n_rmax*cos($theta/2.0)" #calc "$n_rmax*sin($theta/2.0)")        //1
    (0 #calc "$n_rmax*cos($theta/2.0)" #calc "-$n_rmax*sin($theta/2.0)")        //2
    ($xmax 0 0)                                    //3
    ($xmax #calc "$n_rmax*cos($theta/2.0)" #calc "$n_rmax*sin($theta/2.0)")        //4
    ($xmax #calc "$n_rmax*cos($theta/2.0)" #calc "$n_rmax*sin($theta/2.0)")        //5
    //Block 1
    (0 #calc "$n_rmax*cos($theta/2.0)" #calc "$n_rmax*sin($theta/2.0)")        //6
    (0 #calc "$n_rmax*cos($theta/2.0)" #calc "-$n_rmax*sin($theta/2.0)")        //7
    ($xmax #calc "$n_rmax*cos($theta/2.0)" #calc "$n_rmax*sin($theta/2.0)")      //8
    ($xmax #calc "$n_rmax*cos($theta/2.0)" #calc "$n_rmax*sin($theta/2.0)")        //9
    ($xmax #calc "$w_rmax*cos($theta/2.0)" #calc "$w_rmax*sin($theta/2.0)")        //10
    ($xmax #calc "$w_rmax*cos($theta/2.0)" #calc "-$w_rmax*sin($theta/2.0)")    //11
    (0 #calc "$w_rmax*cos($theta/2.0)" #calc "$w_rmax*sin($theta/2.0)")        //12
    (0 #calc "$w_rmax*cos($theta/2.0)" #calc "-$w_rmax*sin($theta/2.0)")        //13
blocks
hex (0 3 5 2 0 3 4 1) (100 100 1) simpleGrading(1 1 1)      //block 0
hex (9 11 13 7 8 10 12 6) (100 100 1) simpleGrading(1 1 1)    //blcok 1
edges
boundary
    front
        type wedge;
    faces
        (3 0 5 2)
        (9 7 13 11)
    back
    type wedge;
    faces
        (4 1 0 3)
        (10 12 6 8)
    inlet
    type wall;
    faces
        (0 1 2 0)
        (6 12 13 7)
    outlet
        type wall;
    faces
        (3 5 4 3)
        (9 11 10 8)
    wedgewall
    type wall;
    faces
        (10 11 13 12)
    needlwall1
    type wall;
    faces
        (4 1 2 5)
    needlwall2
    type wall;
    faces
        (8 6 7 9)
    axis
        type symmetry;
        faces
            (0 3 3 0)
mergePatchPairs
    (needlwall1 needlwall2)
PFA
File Type: zip blockMeshDict.zip (1,015 Bytes, 8 views)
hasha is offline   Reply With Quote
Old   May 17, 2019, 13:39
Rodrigo
guin is on a distinguished road
Just a hint
Ensure to leave an empty space before every $-sign in order to avoid the combination of signs to be interpreted as whole. For instance:
Except for:
"$ .... this should be fine.
guin is offline   Reply With Quote
Old   May 17, 2019, 14:12
Sri harsha Revu
Hello guin,
Thanks for writing back, I have done the same as you said but the error was same. please find the modified blockMeshDict and error reported.
The error it was showing at line 80 but i dont find any extra parenthesis there(highlighted line 80) . could you please help me out.
     \\/     M anipulation  |
FoamFile
    version     6.0;
    format      binary;
    class       dictionary;
w_rmax 7;
n_rmin 0;
n_rmax 0.3;
xmin 0;
xmax 5;
theta 5;
//delta_x 6E-3;
//delta_y 6E-3;
vertices
    //Block 0
    (0 0 0)                                        //0
    (0 #calc "$n_rmax*cos( $theta/2.0)" #calc "$n_rmax*sin( $theta/2.0)")        //1
    (0 #calc "$n_rmax*cos( $theta/2.0)" #calc "- $n_rmax*sin( $theta/2.0)")        //2
    ( $xmax 0 0)                                    //3
    ( $xmax #calc "$n_rmax*cos( $theta/2.0)" #calc "$n_rmax*sin( $theta/2.0)")        //4
    ( $xmax #calc "$n_rmax*cos( $theta/2.0)" #calc "- $n_rmax*sin( $theta/2.0)")        //5
    //Block 1
    (0 #calc "$n_rmax*cos( $theta/2.0)" #calc "$n_rmax*sin( $theta/2.0)")        //6
    (0 #calc "$n_rmax*cos( $theta/2.0)" #calc "- $n_rmax*sin( $theta/2.0)")        //7
    ( $xmax #calc "$n_rmax*cos( $theta/2.0)" #calc "$n_rmax*sin( $theta/2.0)")      //8
    ( $xmax #calc "$n_rmax*cos( $theta/2.0)" #calc "- $n_rmax*sin( $theta/2.0)")        //9
    ( $xmax #calc "$w_rmax*cos( $theta/2.0)" #calc "$w_rmax*sin( $theta/2.0)")        //10
    ( $xmax #calc "$w_rmax*cos( $theta/2.0)" #calc "- $w_rmax*sin( $theta/2.0)")    //11
    (0 #calc "$w_rmax*cos( $theta/2.0)" #calc "$w_rmax*sin( $theta/2.0)")        //12
    (0 #calc "$w_rmax*cos( $theta/2.0)" #calc "- $w_rmax*sin( $theta/2.0)")        //13
blocks
edges
boundary
    front
        type wedge;
    faces
        (3 0 5 2)
        (9 7 13 11)
    back
    type wedge;
    faces
        (4 1 0 3)
        (10 12 6 8)
    inlet
    type wall;
    faces
        (0 1 2 0)
        (6 12 13 7)
    outlet
        type wall;
    faces
        (3 5 4 3)
        (9 11 10 8)
    wedgewall
    type wall;
    faces
        (10 11 13 12)
    needlwall1
    type wall;
    faces
        (4 1 2 5)
    needlwall2
    type wall;
    faces
        (8 6 7 9)
    axis
        type symmetry;
        faces
            (0 3 3 0)
mergePatchPairs
error copied from the terminal
--> FOAM FATAL IO ERROR:
file: /home/harsha/Desktop/test_blockmesh/system/blockMeshDict.faces at line 80.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
    in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
Old   May 17, 2019, 17:19
Rodrigo
The error is due to a a missing semicolon at line 74 right at the end of "faces"-list, from "front" patch.
Nevertheless, you will get further errors. Take a look at the order of the points for the generation of the hex-blocks https://cfd.direct/openfoam/user-guide/v6-blockMesh/
Best,
Old   May 18, 2019, 05:40
Sri harsha Revu
I have checked the blocks the numbering is righthanded every where in the block i even changed it to another style but the error wont change. some body help me , is it a bug why it is showing a wrong token type - expected word, found on line 71 the punctuation token '(' .
     \\/     M anipulation  |
FoamFile
    version     6.0;
    format      ascii;
    class       dictionary;
w_rmax 7;
n_rmin 0;
n_rmax 0.3;
xmin 0;
xmax 5;
theta 5;
//delta_x 6E-3;
//delta_y 6E-3;
vertices
    //Block 0
    (0 0 0)                                        //0
    ( $xmax 0 0)                                    //3
    //Block 1
blocks
hex (0 2 1 0 3 5 4 3) (100 100 1) simpleGrading(1 1 1)      //block 0
hex (7 13 12 6 9 11 10 8) (100 100 1) simpleGrading(1 1 1)    //blcok 1
edges
boundary
    frontAndBack
        type wedge;
    faces
(3 0 5 2)
(9 7 13 11)
(4 1 0 3)
(10 12 6 8)
    /*back
    type wedge;
    faces
        (4 1 0 3)
        (10 12 6 8)
    inlet
    type wall;
    faces
        (0 1 2 0)
        (6 12 13 7)
    outlet
        type wall;
    faces
        (3 5 4 3)
        (9 11 10 8)
    wedgewall
    type wall;
    faces
        (10 11 13 12)
    needlwall1
    type wall;
    faces
        (4 1 2 5)
    needlwall2
    type wall;
    faces
        (8 6 7 9)
    axis
        type symmetry;
        faces
            (0 3 3 0)
mergePatchPairs
Old   March 31, 2022, 07:53
hari charan
saicharan662000@gmail.com is on a distinguished road
Hello hasha,
did you find the solution?
saicharan662000@gmail.com is offline   Reply With Quote
blockmeshdict, openfaom-6
MPI error in parallel application usv001 OpenFOAM Programming & Development 2 September 14, 2017 12:30
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 13:05
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
