May 16, 2019, 04:54 |
CreatePatch error
Dinesh
Rep Power: 8 |
Hello foamers! I have a question.
I am trying to create a compartment geometry inside a fluid domain openfoam. I have created the compartment wall and burner using topoSet and extrudeRegionToMesh. Now I have to patch the burner's upper surface as an inlet. When I tried createPatch command I got the following error. "-> FOAM FATAL ERROR: cannot find file "/mnt/e/OpenFOAM/Tutorialsv1812/comp_Fire_Trial1-Success/constant/polyMesh/sets/fBurner" From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 532. FOAM exiting" If you know what is this problem please let me know |
May 23, 2019, 05:32 |
#2 | |
Thomas Sprich
Rep Power: 11 |
Hi Dinesh,
Do you maybe have a typo somewhere in your setup. See the red: Quote:
Other than that, you would need to post your createPatchDict, topoSetDict etc. so that someone can help you. The more information you provide, the better the chances of a helpful response. Good luck, Thomas |
May 23, 2019, 23:26 |
Dinesh
Rep Power: 8 |
First of all, thank you very much for your response Thomas Sprich.
yes, you're right. It was my typo mistake. |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
