zool
Rep Power: 7 ![]() |
Imagine stimulation of laminar flame (in e.g Bunsen burner in 2D since the problem is axi-symmetric) - the real geometry is more complex so many blocks are needed. I have to option to use half a plane in xy plane and extrude it along z (small thickness) and choose the xz plane as Symmetryplane. Or use the wedge (which there is no good tutorial that explain it fully)
Will there be a big difference? suggestions? |
Ajith U K Nair
Rep Power: 4 ![]() |
Were u able to set the bunsen burner case. I haverun some simulations on it using reacting foam single step chemistry. But the temperature profiles are nonphysical. If you have your case setup kindly share.
Symmetryplane, cyclic and wedge boundary conditions | Taltan | OpenFOAM Pre-Processing | 7 | April 18, 2023 11:31 |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
axisymmetric wedge case problem | comedy_tigers88 | OpenFOAM Running, Solving & CFD | 0 | June 16, 2012 04:45 |
Wall boundary is ignored when using wedge | Wedge | OpenFOAM | 1 | February 7, 2011 06:20 |
