checkMesh fails, non closed Cells is there any possibility to close them? |
April 23, 2019, 11:40 |
Rep Power: 7 |
Hi everyone,
I have a Mesh which has different kind of grids: the structured and there is some unstructured parts. When I try to convert the mesh, everything goes fine, but the checkMesh fails 2 checks. It seems, that there are some open Cells in this "intersection". Is there any possibility to patch this? this is the checkMesh response: Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 1368793 faces: 4929396 internal faces: 4794724 cells: 1823654 faces per cell: 5.33222 boundary patches: 15 point zones: 0 face zones: 4 cell zones: 4 Overall number of cells of each type: hexahedra: 1194739 prisms: 0 wedges: 0 pyramids: 23181 tet wedges: 0 tetrahedra: 588889 polyhedra: 16845 Breakdown of polyhedra by number of faces: faces number of cells 5 16845 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 5 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 296709 cells to cellSet region0 <<Writing region 1 with 315361 cells to cellSet region1 <<Writing region 2 with 1008832 cells to cellSet region2 <<Writing region 3 with 101376 cells to cellSet region3 <<Writing region 4 with 101376 cells to cellSet region4 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology OUTLET_UNTEN 6120 6290 ok (non-closed singly connected) INLET_UNTEN 6120 6290 ok (non-closed singly connected) INLET 3168 3241 ok (non-closed singly connected) OUTLET 3168 3241 ok (non-closed singly connected) DISH 26704 26932 ok (non-closed singly connected) S_FLAECHE 16888 17409 ok (non-closed singly connected) INLET_OBEN 4608 4752 ok (non-closed singly connected) INLET_UNSTRUCTERED 7166 3740 ok (non-closed singly connected) OUTLET_OBEN 4608 4752 ok (non-closed singly connected) OUTLET_UNSTRUCTURED 7204 3759 ok (non-closed singly connected) IN-INT1 6336 3241 multiply connected (shared edge) IN-INT2 8630 8692 multiply connected (shared edge) OUT-INT2 8296 8352 multiply connected (shared edge) OUT-INT1 6336 3241 multiply connected (shared edge) SURFS 19320 19897 ok (non-closed singly connected) <<Writing 6551 conflicting points to set nonManifoldPoints Checking geometry... Overall domain bounding box (-0.01775 2.5e-05 -0.004) (0.01775 0.018025 0.004) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) ***Boundary openness (2.82431e-06 -6.98109e-07 2.86331e-07) possible hole in boundary description. ***Open cells found, max cell openness: 0.719538, number of open cells 16845 <<Writing 16845 non closed cells to set nonClosedCells Minimum face area = 3.97624e-13. Maximum face area = 1.13676e-07. Face area magnitudes OK. Min volume = 2.91583e-19. Max volume = 1.07276e-11. Total volume = 5.62536e-07. Cell volumes OK. Mesh non-orthogonality Max: 86.021 average: 24.1218 *Number of severely non-orthogonal (> 70 degrees) faces: 7902. Non-orthogonality check OK. <<Writing 7902 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.51785 OK. Coupled point location match (average 0) OK. Failed 2 mesh checks. End ------------------------ |
May 2, 2019, 03:25 |
Hello Ventins,
I don't think so, it has anything to do with mesh conversion. Improve your mesh quality in your mesh generating tool. Also, you have pretty high mesh non-orthogonality. Even, if you don't get any problem with open faces. You might face problems due to high non-orthogonality. |
May 6, 2019, 08:04 |
Rep Power: 7 |
Thank you, very much for your reply! I'll try to improve the mesh.
And while I'm at it, I should get rid of those internal walls |
[Other] How to delete cells in OF based on CheckMesh? | AndTen | OpenFOAM Meshing & Mesh Conversion | 15 | July 27, 2018 06:13 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] Advice on how to keep cells inside a closed contour | CrisMoreira | OpenFOAM Meshing & Mesh Conversion | 7 | July 23, 2015 12:16 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
