fvschemes for laminar particles of fluidisedBed
Old   April 15, 2019, 22:33
Default fvschemes for laminar particles of fluidisedBed
gryphaea1635 is on a distinguished road
I'm trying to simulate a fluidized bed (through modifying the pre-installed twoPhaseEulerFoam tutorial case). I want the gas phase to use the RAS kEpsilon model, and for the particles to have laminar flow. Thus, for my particles turbulence properties I set the simulationType to laminar, and kept the kEpsilon model for the gas turbulence properties. However, when I ran the solver, I got an error message that said:
keyword div((((alpha.particles*thermo:rho.particles)*nuEff.particles)*dev2(T(grad(U.particles))))) is undefined in dictionary "/home/alfred/OpenFOAM/alfred-6/run/fluidisedBedlaminarparticles/system/fvSchemes.divSchemes"
file: /home/alfred/OpenFOAM/alfred-6/run/fluidisedBedlaminarparticles/system/fvSchemes.divSchemes from line 30 to line 44.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 566.
It looks like I have to change my divSchemes. However, I'm not very experienced with CFD, so I still have to learn about the underlying computational processes and I'm not sure what to modify.
fvSchemes:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default     Euler;
gradSchemes
    default     Gauss linear;
divSchemes
    default                         none;
    "div\(phi,alpha.*\)"            Gauss vanLeer;
    "div\(phir,alpha.*\)"           Gauss vanLeer;
    "div\(alphaRhoPhi.*,U.*\)"      Gauss limitedLinearV 1;
    "div\(phi.*,U.*\)"              Gauss limitedLinearV 1;
    "div\(alphaRhoPhi.*,(h|e).*\)"  Gauss limitedLinear 1;
    "div\(alphaRhoPhi.*,K.*\)"      Gauss limitedLinear 1;
    "div\(alphaPhi.*,p\)"           Gauss limitedLinear 1;
    div(alphaRhoPhi.particles,Theta.particles) Gauss limitedLinear 1;
    "div\(alphaRhoPhi.*,(k|epsilon).*\)"  Gauss limitedLinear 1;
    div((((alpha.air*thermo:rho.air)*nuEff.air)*dev2(T(grad(U.air))))) Gauss linear;
    div((((thermo:rho.particles*nut.particles)*dev2(T(grad(U.particles))))+(((thermo:rho.particles*lambda.particles)*div(phi.particles))*I)))  Gauss linear;
laplacianSchemes
    default     Gauss linear uncorrected;
    bounded     Gauss linear uncorrected;
interpolationSchemes
    default     linear;
snGradSchemes
    default     uncorrected;
    bounded     uncorrected;
turbulenceProperties.air:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties.air;
simulationType  RAS;
RAS
    RASModel kEpsilon;
    turbulence      on;
    printCoeffs     on;
LES
    LESModel Smagorinsky;
    turbulence      on;
    printCoeffs     on;
    delta cubeRootVol;
    cubeRootVolCoeffs
        deltaCoeff 1;
turbulenceProperties.particles:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      turbulenceProperties.particles;
simulationType  laminar;
RAS
    RASModel kineticTheory;
    turbulence      on;
    printCoeffs     on;
    kineticTheoryCoeffs
        equilibrium             off;
        e                       0.8;
        alphaMax                0.62;
        alphaMinFriction        0.5;
        residualAlpha           1e-4;
        viscosityModel          Gidaspow;
        conductivityModel       Gidaspow;
        granularPressureModel   Lun;
        frictionalStressModel   JohnsonJackson;
        radialModel             SinclairJackson;
        JohnsonJacksonCoeffs
            Fr                      0.05;
            eta                     2;
            p                       5;
            phi                     28.5;
            alphaDeltaMin           0.05;
    phasePressureCoeffs
        preAlphaExp     500;
        expMax          1000;
        alphaMax        0.62;
        g0              1000;
How should I modify my fvSchemes or turbulenceProperties.particles so that I can simulate a fluidized bed with a laminar particle phase?
Thank you!!
gryphaea1635 is offline   Reply With Quote
Old   April 26, 2020, 17:10
Default Re: fvschemes for laminar particles of fluidisedBed
Roberto Lepera
rrronny is on a distinguished road
Send a message via Skype™ to rrronny
Hi, gryphaea1635! I only read your message now. I have solved this problem by adding the follow line in divSchemes:
div\(\(\(\(alpha.*\*thermo:rho.*\)*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear;
rrronny is offline   Reply With Quote
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 05:08
dsmcFoam - micro-hole limiting the number of dsmc particles Araist OpenFOAM Running, Solving & CFD 0 June 25, 2015 07:50
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 04:10
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 22:33
particles model ati_ros61 FLOW-3D 3 December 6, 2009 17:03
