April 11, 2019, 12:19 |
fvSolution wildcard final
Rep Power: 15 |
I found under $FOAM_TUTORIALS/compressible/rhoPimpleFoam/RAS/angledDuctLTS/system/fvSolution following code. Code:
"(rho|U|h|k|epsilon|omega)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } "(rho|U|h|k|epsilon|omega)Final" { $U; tolerance 1e-05; relTol 0.1; } Why U? Is it the same as writing the *Final statement for each single variable? (rhoFinal, UFinal, ...) |
April 11, 2019, 19:44 |
Rep Power: 15 |
It means it is using the same solver/smoother as U.
Caelan |
August 29, 2019, 17:07 |
#3 | |
Rep Power: 7 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
