Joints of a geometry not snapped well (SnappyHexMesh) |
April 10, 2019, 04:35 |
Malini Dasgupta
Rep Power: 7 |
Hello everyone,
I am relatively new to openFoam and I am trying to mesh a wedge-shaped geometry with a bore at the center to examine jet mixing. For simplicity I have divided the geometry into 3 parts- the middle part has a higher refinement than the top and bottom parts. However the problem I encounter is that the joints between the 3 part geometry doesn't snap very well using SHM. Can anyone please tell me what I could do here? Will a refinement box do in those regions? Also checkMesh says the Mesh is ok, but I am a little apprehensive about setting up the case with this mesh. Any help will be really appreciated. I am attaching a link to folder with relevant screenshots https://drive.google.com/open?id=1UM...9aGHHsc4MXILbG |
April 15, 2019, 13:09 |
Rep Power: 13 |
Hi. How good or bad are the results if you snap onto single/ entire geometry? Unlike the screenshots, the snappyHexMeshDict is for a single/ undivided geometry isn't it?
Have you tried tinkering with 'resolveFeatureAngle'? That usually does yield better 'corner' fitting, although broadly speaking SHM has its issues with sharp edges. |
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh | czhongrong | OpenFOAM Meshing & Mesh Conversion | 1 | January 20, 2016 06:26 |
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) | Irish09 | OpenFOAM Meshing & Mesh Conversion | 23 | July 15, 2013 08:45 |
[snappyHexMesh] snappyHexMesh with zero Thickness surface imported from a Geometry | hfs | OpenFOAM Meshing & Mesh Conversion | 0 | September 4, 2012 12:41 |
[snappyHexMesh] Parts of Geometry not meshed by snappyHexMesh | Turbulence | OpenFOAM Meshing & Mesh Conversion | 5 | August 8, 2012 17:27 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
