March 25, 2019, 10:58 |
Problems with setFields
Paul
Rep Power: 7 |
Hi all,
I am having difficulties with the setFields function. I am attempting to run a modified damBreak example, but I am unable to properly initialize water where I want it. To make the modified mesh, I copied the damBreak tutorial to my run directory, and made some small edits to the mesh. After running blockMesh and modifying setFieldsDict, I attempted to run setFields. It successfully ran with no errors, however, the water is only appearing on the walls of my mesh (with no water in the interior). I have attached a picture of what I am seeing in paraFoam. I have tried troubleshooting this in various ways. I completely rewrote setFieldsDict, I copied alpha.water.orig to alpha.water before running setFields, etc. I am still unable to properly set water where I want it. Any help you can provide would be much appreciated and if you need anything else from me, just let me know. Thank you. |
March 26, 2019, 09:28 |
A bit of context would be nice. Could you post "some small edits to the mesh"? Could you post your setFieldsDict modifications? |
March 26, 2019, 10:23 |
#3 | |
Paul
Rep Power: 7 |
Here is my blockMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (0 0 0) (60 0 0) (60 44.45 0) (0 44.45 0) (0 21.825 0) (0 22.625 0) (-10 22.625 0) (-10 21.825 0) (0 0 1) (60 0 1) (60 44.45 1) (0 44.45 1) (0 21.825 1) (0 22.625 1) (-10 22.625 1) (-10 21.825 1) (60 21.825 0) (60 21.825 1) (60 22.625 0) (60 22.625 1) ); blocks ( hex (0 1 16 4 8 9 17 12) (20 20 1) simpleGrading (1 1 1) hex (4 16 18 5 12 17 19 13) (20 5 1) simpleGrading (1 1 1) hex (5 18 2 3 13 19 10 11) (20 20 1) simpleGrading (1 1 1) hex (4 5 6 7 12 13 14 15) (5 5 1) simpleGrading (1 1 1) ); edges ( ); boundary ( leftWall { type wall; faces ( (0 8 12 4) (5 13 11 3) (7 15 14 6) (6 14 13 5) (3 11 10 2) (0 1 9 8) (4 12 15 7) ); } atmosphere { type patch; faces ( (16 18 19 17) (18 2 10 19) (1 16 17 9) (0 4 16 1) (4 5 18 16) (5 3 2 18) (8 9 17 12) (12 17 19 13) (13 19 10 11) (7 6 5 4) (15 12 13 14) ); } ); mergePatchPairs ( ); // ************************************************************************* // And here is my setFieldsDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (0 0 -0.02) (0.05 0.018 0.02); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); // ************************************************************************* // I do not believe I changed anything else from the damBreak tutorial (which may be the reason I'm having trouble). Thank you again |
dambreak, setfields, setfieldsdict |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
rhoSimplecFoam with setFields | sino75 | OpenFOAM Pre-Processing | 0 | March 11, 2015 04:08 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
