mapFields with moving meshes
Old   February 22, 2019, 07:07
Default mapFields with moving meshes
Bazinga is on a distinguished road
I am facing a problem where I have a moving body with sixDoFRigidBodyMotion and I want to check the sensitivity of the results regarding coarser/finer meshes. When I initialize on a different mesh, the location of the body and the mesh deformation information is not mapped to the new field.
Does anyone have a solution to this problem?
Bazinga is offline   Reply With Quote
Old   February 22, 2019, 09:20
anonymous
simrego is on a distinguished road
Hi!
Is it even possible? With dynamic mesh you have a "new mesh" at every step. Actually new points if there are no topological changes.
I think you can only map fields but not the actual point locations of the mesh. Your mesh is distorted. I think in most of the cases it is nearly impossible. For example you have a wing which is moved upwards. Then you try to map these mesh points into a new mesh, but there will be many points without overlapping and it is a nightmare. Also you have no idea which point was which. Even if you map field from one mesh to another and if the domain is not the same the mapping algorithm can do interesting things especially where you should map data from outside of the source domain.
What if you just run the solver with local time stepping (if the solver has this functionality) from the beginning to reach the steady state solution and then run the pure transient part.
simrego is offline   Reply With Quote
Issues with mapFields BlackBoatNavArch OpenFOAM Pre-Processing 38 May 28, 2021 17:29
Moving meshes: Arbitrary Lagrangian-Eulerian (ALE) formulation Joachim Main CFD Forum 0 August 29, 2014 12:03
Confirmation Needed on fvMeshSubset and Moving Meshes ngj OpenFOAM Programming & Development 1 September 17, 2010 09:06
Problems with mapFields and moving mesh. ghindi OpenFOAM Pre-Processing 2 April 25, 2010 06:56
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 10:45
