Air Conditioner modeling in OpenFOAM
Old   February 13, 2019, 09:41
Default Air Conditioner modeling in OpenFOAM
Bhargav lakhlani
bhargav1195 is on a distinguished road
I want to model an Air conditioner in a room with the following input,
1) Cooling/Heating capacity of AC
2) The flow rate of supply air
3) The temperature of supply air
I have tried the following approach
A) At the supply air boundary patch, I specified the velocity and temperature
B) At the return air boundary patch, I specified static pressure = O bar
Problem:
Is the aforementioned approach of setting zero static pressure at return air opening is correct?
How do I implement the capacity of AC?
Additionally, How can I specify the opening ratio of the panel which is supplying air?
Note: Please consider the case related to Data Center modeling for the above problem.
Thank You.
Regards,
Bhargav Lakhlani
bhargav1195 is offline   Reply With Quote
air conditioner, cooling capacity, data center, opening ratio
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
modeling condensation in humid air... a.mashayekh FLUENT 9 May 7, 2015 20:12
Modeling the Earth's Mantle: is OpenFOAM a good candidate? decapitor OpenFOAM Running, Solving & CFD 4 January 18, 2012 20:13
