How is a fixedValue BC extrapolated to first cell? |
February 13, 2019, 05:21 |
Rep Power: 11 |
Hi all,
I'm running a very simple case with simpleFoam (kEpsilon), where I have a rough wall patch. For this patch I choose to use the 'noSlip' BC for velocity which turns out to be a wrapper for fixedValue with value (0 0 0). 1) How is this fixed velocity at the wall extrapolated to the first cell? (Or where can I see how the extraploation is treated/defined?) 2) Other question - In my case I have roughness elements of length ~ 0.5 x dimension of the first cell. Is there a BC type where I can account for the effect on the velocity due to the roughness of the wall Thank you! Chris |
February 13, 2019, 05:30 |
Rep Power: 11 |
What I mean with 'extrapolate' is, how it affects the first cells value...
February 13, 2019, 08:24 |
#3 | |
Rep Power: 11 |
Ok, if I'm not much mistaken, this is done through the nut*RoughWallFunction? |
February 13, 2019, 16:43 |
#4 | ||
Rep Power: 11 |
boundary condition, rough wall, velocity bc |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Doubt about parallel processing | vishwesh | OpenFOAM Programming & Development | 0 | November 10, 2017 06:20 |
Partition: cell count = 0 | metmet | FLUENT | 1 | August 31, 2014 19:41 |
monitoring cell | Jane | Siemens | 2 | March 4, 2004 21:01 |
cell to cell relation | CMB | Siemens | 1 | December 4, 2003 04:05 |
