Cyclic boundary condition in foam-extend 4.0
Old   February 12, 2019, 10:01
Default Cyclic boundary condition in foam-extend 4.0
Ville
rellumeister is on a distinguished road
Hello!
I'm working on a result validation setup for a LES pipe flow using immersed boundary conditions to model the pipe wall. The idea is to loop an initially fully-developed and perturbed laminar flow profile through the pipe, so the cyclic neighbors are surprisingly the inlet and the outlet of the pipe.
I have produced a similar setup in OF5 with a body-fitted mesh using the following blockMeshDict file, boundary file and initial boundary conditions (please keep in mind, that the actual initial U-field is modified to the perturbed fully-developed profile and is not shown below. However, the boundary conditions apply):
|  \\    /   O peration     | Version:  2.1.0                                  |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.com               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (  0  0  0 )          //0
    (  0  0  6. )          //1
    ( -0.2 -0.2  0 )               //2
    ( -0.2 -0.2  6. )        //3
    (  0.2 -0.2  0 )               //4
    (  0.2 -0.2  6. )        //5
    (  0.2  0.2  0 )               //6
    (  0.2  0.2  6. )        //7
    ( -0.2  0.2  0 )               //8
    ( -0.2  0.2  6. )        //9
    (  0.353553390593274  0.353553390593274  0 )           //10
    (  0.353553390593274  0.353553390593274  6. )    //11
    ( -0.353553390593274  0.353553390593274  0 )           //12
    ( -0.353553390593274  0.353553390593274  6. )    //13
    ( -0.353553390593274 -0.353553390593274  0 )           //14
    ( -0.353553390593274 -0.353553390593274  6. )    //15
    (  0.353553390593274 -0.353553390593274  0 )           //16
    (  0.353553390593274 -0.353553390593274  6. )    //17
blocks
    //Pipe blocks
    hex (2 4 6 8 3 5 7 9) (20 20 50) simpleGrading (1 1 1)          //0 inner block
    hex (16 10 6 4 17 11 7 5) (20 40 50) simpleGrading ( 1 9 1 )
    hex (10 12 8 6 11 13 9 7) (20 40 50) simpleGrading ( 1 9 1 )
    hex (12 14 2 8 13 15 3 9) (20 40 50) simpleGrading ( 1 9 1 )
    hex (14 16 4 2 15 17 5 3) (20 40 50) simpleGrading ( 1 9 1 )
 edges
      arc  10 12 (  0  0.5  0 )
      arc  11 13 (  0  0.5  6. )
      arc 12 14  ( -0.5  0  0 )
      arc 13 15  ( -0.5  0  6. )
      arc 14 16 ( 0  -0.5  0 )
      arc 15 17 ( 0  -0.5  6. )
     arc  16 10 (  0.5  0  0 )
     arc  17 11 (  0.5  0  6. )
boundary
     inlet
          type cyclic;
           neighbourPatch outlet;
         faces
             (2 4 6 8)
             (4 16 10 6)
             (10 12 8 6)
             (12 14 2 8)
             (14 16 4 2)
     outlet
         type cyclic;
           neighbourPatch inlet;
           faces
             (3 5 7 9)
             (17 11 7 5)
             (11 13 9 7)
             (13 15 3 9)
             (15 17 5 3)
     walls
         type wall;
         faces
             (10 11 17 16)
             (10 11 13 12)
             (12 13 15 14)
             (14 15 17 16)
mergePatchPairs
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      binary;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
3
    inlet
        type            cyclic;
        inGroups        1(cyclic);
        nFaces          3600;
        startFace       534400;
        matchTolerance  0.0001;
        transform       unknown;
    outlet
        type            cyclic;
        inGroups        1(cyclic);
        nFaces          3600;
        startFace       538000;
        transform       unknown;
    walls
        type            wall;
        inGroups        1(wall);
        nFaces          4000;
        startFace       541600;
|  \\    /   O peration     | Version:  2.4.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type cyclic;
    outlet
        type cyclic;
    walls
        type noSlip;
This setup, keeps the laminar profile for some time until it destabilizes. So, I wish to accomplish a similar setup in foam-extend using the immersed boundary method. While writing this, I have not yet managed to create the perturbed and developed flow profile for the immersed boundary method, but instead I am initializing a uniform flow field with potentialFoam. It seems as though Foam-extend's cyclic boundary condition has to be set differently (the neighbor cyclic faces being under the same boundary condition), and I have managed to get the setup to run with the following files (mind here that the cylinder wall is introduced as a .ftr file during simulation, so it cannot be clearly seen in the setup files):
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
    (-0.7    -0.7    0)    //0
    (-0.7    0.7    0)    //1
    (0.7    0.7    0)    //2
    (0.7    -0.7    0)    //3
    (-0.7    -0.7    6)    //4
    (-0.7    0.7    6)    //5
    (0.7    0.7    6)    //6
    (0.7    -0.7    6)    //7
blocks
    //Pipe blocks
    hex (5 6 7 4 1 2 3 0) (20 20 42) simpleGrading (1 1 1)
edges
boundary
     inletOutlet
          type cyclic;
         faces
             (4 5 6 7)
             (3 2 1 0)
     walls
         type patch;
         faces
             (2 3 7 6)
             (0 1 5 4)
             (0 4 7 3)
             (1 2 6 5)
mergePatchPairs
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     4.0                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
FoamFile
    version     2.0;
    format      ascii;
    object      boundary;
3
    ibCylinder
        type            immersedBoundary;
        nFaces          0;
        startFace       48320;
        internalFlow    no;
    inletOutlet
        type            cyclic;
        nFaces          800;
        startFace       48320;
        featureCos      0.9;
    walls
        type            patch;
        nFaces          3360;
        startFace       49120;
FoamFile
    version     2.0;
    format      ascii;
    object      U;
internalField   uniform (0 0 1.0);
boundaryField
    ibCylinder
        refValue uniform (0 0 0);
        refGradient  uniform (0 0 0);
        fixesValue yes;
        setDeadCellValue   yes;
        deadCellValue      (0 0 0);
        value uniform (0 0 0);
     inletOutlet
        type cyclic;
    walls
        type slip;
At first, the velocity profile starts to develop into a parabolic shape. However, the flow velocity maximum stays at the initialized bulk value and as the simulation progresses the flow loses momentum, i.e. momentum is lost in time.
The immersed boundary should not be the problem here, since a similar setup with separate inlet and outlet conditions do in fact produce a parabolic velocity profile. So I am led to believe that the problem lies in the cyclic boundary condition.
Am I setting up the cyclic boundary condition correctly for foam-extend? Any great ideas?
Br. Ville
rellumeister is offline   Reply With Quote
Old   June 28, 2019, 07:49
Thang
thang_cegroup is on a distinguished road
Do you find the answer yet ?
thang_cegroup is offline   Reply With Quote
Old   March 3, 2020, 09:03
Torsten Schenkel
tschenkel is on a distinguished road
What is driving your flow? You will need a friving force. In OpenFOAM you could use and averageVelocity source in fvOptions. In foam-extend a pressure jump over the cyclic boundary should do.
Haven't tested, but if you only have cyclic, it will eventually stop flowing as the inertia is eaten up by friction.
tschenkel is offline   Reply With Quote
cyclic boundary condition, foam extend 4.0
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox manuc OpenFOAM Running, Solving & CFD 1 April 12, 2022 12:36
Setting up cyclic boundary condition KateEisenhower OpenFOAM Pre-Processing 6 January 11, 2017 18:17
Cyclic Boundary Condition Errors? nyflyer OpenFOAM Running, Solving & CFD 2 April 26, 2016 15:14
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
