February 11, 2019, 19:21 |
ideasUnvToFoam issue
julien
Rep Power: 7 |
I want to do again the same simple 2D case that (solver chtMultiRegionSimpleFoam) ChtMultiRegion changeDirectory But I want to be able to mesh my next cases in a simple way. I had a look on snappyHexMesh with CHT problems and it seems very difficult to do. So I try a more direct way with Salome. I reproduce the exact geometry and exact mesh with salome that created with blockMesh (see picture) I have done the following: - create geometry 2D (2 fluids 1 solid) - I have mesh each 2D domain - I have extrude the 2D meshes into to 3D with 1 cell thick (a long way to get the boundary groups, but it works) - All boundaries are defined in groups (inlet, boundaries between domains, outlets...) - I made a compound mesh with the 3 domains meshes. (I remove all the vertex, edge and volume groups created by default, keeping only the surface groups). - I have a folder case (see picture) - I run the command "ideasUnvToFoam Mesh_compound.unv" With the log resulting seems ok: Of 51050 so-called boundary faces 200 belong to two cells and are therefore internal Sorting boundary faces according to group (patch) 0: minXplate_extruded is patch 1: plate_to_botAir_extruded is faceZone 2: plate_to_topAir_extruded is faceZone 3: maXplate_extruded is patch 4: top_bottom_plate is patch 5: inlet_botAir_extruded is patch 6: minZ_botAir_extruded is patch 7: outlet_botAir_extruded is patch 8: botAir_to_plate_extruded is faceZone 9: top_bottom_botAir is patch 10: inlet_topAir_extruded is patch 11: topAir_to_plate_extruded is faceZone 12: maxZ_topAir_extruded is patch 13: outlet_topAir_extruded is patch 14: top_bottom_topAir is patch Constructing mesh with non-default patches of size: minXplate_extruded 50 maXplate_extruded 100 top_bottom_plate 10100 inlet_botAir_extruded 100 minZ_botAir_extruded 100 outlet_botAir_extruded 100 top_bottom_botAir 20000 inlet_topAir_extruded 100 maxZ_topAir_extruded 100 outlet_topAir_extruded 100 top_bottom_topAir 20000 Adding cell and face zones Face Zone botAir_to_plate_extruded 100 Face Zone topAir_to_plate_extruded 100 Face Zone plate_to_botAir_extruded 100 Face Zone plate_to_topAir_extruded 100 End It creates a polyMesh folder in constant/ - The next step is the command "splitMeshRegions -cellZones -overwrite" Number of regions:1 The log result is: Writing region per cell file (for manual decomposition) to "C:/PROGRA~1/BLUECF~1/OFUSER~1/run/CHT_1solid_salomeCopie/constant/cellToRegion" Writing region per cell as volScalarField to "C:/PROGRA~1/BLUECF~1/OFUSER~1/run/CHT_1solid_salomeCopie/0/cellToRegion" Region Cells ------ ----- 0 25050 Region Zone Name ------ ---- ---- 0 -1 domain0 Sizes of interfaces between regions: Interface Region Region Faces --------- ------ ------ ----- Reading volScalarField cellToRegion Only one region. Doing nothing. End - What is the problem ? Best regards |
February 13, 2019, 15:20 |
julien
Rep Power: 7 |
I found that I need also the add the domains in mesh groups, and after running
"splitMeshRegions -cellZones -overwrite" I have all the domains and boundaries well defined. The command checkMesh gives no warning. I run also the command transformPoints -scale '(0.001 0.001 0.001)' to convert into meter my mesh coming from Salome. I start the chtMultiRegionSimpleFoam calculation, it runs the first 152 iterations and it crashes. I have keep all the BC and fvScheme et fvSolutions than my first case created with blockMesh. The error when it crashs is: Time = 152 Solving for fluid region GrbotAir_Volumes DILUPBiCG: Solving for Ux, Initial residual = 0.382244511, Final residual = 0.000484013494, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.335275599, Final residual = 0.000504403178, No Iterations 3 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0897453108, No Iterations 3 Min/max T:400 500 DICPCG: Solving for p_rgh, Initial residual = 0.521602535, Final residual = 0.0514694741, No Iterations 8 DICPCG: Solving for p_rgh, Initial residual = 0.0243979882, Final residual = 0.00205952534, No Iterations 34 DICPCG: Solving for p_rgh, Initial residual = 0.00077404709, Final residual = 6.74546295e-005, No Iterations 43 time step continuity errors : sum local = 1.27416883e+023, global = 1.3403119e+021, cumulative = -1.48069445e+049 Min/max rho:0.2 2 Solving for fluid region GrtopAir_Volumes DILUPBiCG: Solving for Ux, Initial residual = 0.999914293, Final residual = 4.50959413e-010, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.999914293, Final residual = 8.33926922e-010, No Iterations 3 Generating stack trace... Backtrace: ZN10StackTraceC1Ev [0x705c1465+0x25] module: C:\PROGRA~1\BLUECF~1\ThirdParty-5.x\platforms\mingw_w64GccDPInt32\lib\libstack_tra ce.dll ZN4Foam5error10printStackERNS_7OstreamE [0x1201c88+0x218] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFO AM.dll ZN4Foam6sigFpe13sigFpeHandlerEi [0x1202af3+0x33] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFO AM.dll (No symbol) [0x40468d] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\chtMultiR egionSimpleFoam.exe _C_specific_handler [0x7ff8c9bf7c58+0x98] module: C:\WINDOWS\System32\msvcrt.dll 0_chkstk [0x7ff8cc7df7dd+0x11d] module: C:\WINDOWS\SYSTEM32\ntdll.dll RtlWalkFrameChain [0x7ff8cc74d856+0x13f6] module: C:\WINDOWS\SYSTEM32\ntdll.dll KiUserExceptionDispatcher [0x7ff8cc7de70e+0x2e] module: C:\WINDOWS\SYSTEM32\ntdll.dll ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_ [0x11a7deb+0x2b] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFO AM.dll ZN4Foam8gSumProdIdEEdRKNS_5UListIT_EES5_i [0x12e830d+0xd] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFO AM.dll ZNK4Foam5PBiCG5solveERNS_5FieldIdEERKS2_h [0x10a5e62+0x602] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFO AM.dll ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictio naryE [0x65ef1c17+0x127] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libfinite Volume.dll (No symbol) [0x44f711] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\chtMultiR egionSimpleFoam.exe (No symbol) [0x44f9b5] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\chtMultiR egionSimpleFoam.exe (No symbol) [0x486a91] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\chtMultiR egionSimpleFoam.exe (No symbol) [0x4013f7] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\chtMultiR egionSimpleFoam.exe (No symbol) [0x40152b] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\chtMultiR egionSimpleFoam.exe BaseThreadInitThunk [0x7ff8ca493dc4+0x14] module: C:\WINDOWS\System32\KERNEL32.DLL RtlUserThreadStart [0x7ff8cc7b3691+0x21] module: C:\WINDOWS\SYSTEM32\ntdll.dll Someone has any idea of what is wrong ? Best regards |
February 13, 2019, 16:26 |
julien
Rep Power: 7 |
Ok, I found that it is not good to create groups for inside boundaries between domains. The command "splitMeshRegions -cellZones -overwrite" creates itself these boundaries.
So I have results close to these obtained with blockMesh but I have a strange fluctuation close to the outlet of the top air domain giving waves in monitoring error curves and in field T Heat flux is fluctated also at the fluid/ solid interface giving close to 130 W at the boundary. 131 W for the bockMesh case. I don't know if someone find difference between CAD mesh and blockMesh for 2 identical mesh. |
February 13, 2019, 18:18 |
julien
Rep Power: 7 |
The converge curve for the top fluid domain is pretty bad
February 13, 2019, 18:35 |
julien
Rep Power: 7 |
I post the differences between meshes obtained with Salome and blockMesh:
Salome Mesh : Mesh stats points: 50802 internal points: 0 faces: 100550 internal faces: 49700 cells: 25050 faces per cell: 5.99800399 boundary patches: 11 point zones: 0 face zones: 0 cell zones: 3 Overall number of cells of each type: hexahedra: 25000 prisms: 50 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology minXplate 50 102 ok (non-closed singly connected) maxXplate 100 202 ok (non-closed singly connected) top_bottom_plate 10100 10402 ok (non-closed singly connected) inlet_botAir 100 202 ok (non-closed singly connected) minZ_botAir 100 202 ok (non-closed singly connected) outlet_botAir 100 202 ok (non-closed singly connected) top_bottom_botAir 20000 20402 ok (non-closed singly connected) inlet_topAir 100 202 ok (non-closed singly connected) maxZ_topAir 100 202 ok (non-closed singly connected) outlet_topAir 100 202 ok (non-closed singly connected) top_bottom_topAir 20000 20402 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 0) (0.5 1 0.5) Mesh has 2 geometric (non-empty/wedge) directions (1 0 1) Mesh has 2 solution (non-empty) directions (1 0 1) All edges aligned with or perpendicular to non-empty directions. Boundary openness (0 -4.86129149e-017 0) OK. Max cell openness = 1.26904551e-016 OK. Max aspect ratio = 12.5 OK. Minimum face area = 1e-006. Maximum face area = 0.00586026339. Face area magnitudes OK. Min volume = 1e-006. Max volume = 2.9301317e-005. Total volume = 0.25. Cell volumes OK. Mesh non-orthogonality Max: 68.1985905 average: 2.87277745 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.229088402 OK. Coupled point location match (average 0) OK. Mesh OK. End Mesh obtained with blockMesh: Mesh stats points: 50702 internal points: 0 faces: 100350 internal faces: 49650 cells: 25000 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 3 Overall number of cells of each type: hexahedra: 25000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology maxY 100 202 ok (non-closed singly connected) minX 250 502 ok (non-closed singly connected) maxX 250 502 ok (non-closed singly connected) minY 100 202 ok (non-closed singly connected) defaultFaces 50000 50702 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -0.25 0) (0.5 0.25 1) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (2.77555756e-017 -4.4408921e-017 -1.16624917e-015) OK. Max cell openness = 1.87459585e-016 OK. Max aspect ratio = 55.2387824 OK. Minimum face area = 3.64820042e-007. Maximum face area = 0.0100379816. Face area magnitudes OK. Min volume = 3.64820042e-007. Max volume = 9.12050095e-005. Total volume = 0.25. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 4.09891609e-014 OK. Coupled point location match (average 0) OK. Mesh OK. End I see that I have Mesh non orthogonality with Salome, do I have to modify something in the solver due to non orthogonalities ? Any advises would be welcome Best regards |
[Salome] ideasUnvToFoam Error: Assertion `nouveau > -1' failed | GerhardHolzinger | OpenFOAM Meshing & Mesh Conversion | 1 | November 7, 2024 07:49 |
CAMWA special issue on open-source numerical solver | feixu2019 | OpenFOAM Announcements from Other Sources | 0 | October 1, 2018 12:21 |
CAMWA special issue on open-source numerical solver | feixu2019 | SU2 News & Announcements | 0 | October 1, 2018 12:19 |
[Salome] ideasUnvToFoam problem with internal groups | s.marcocalero | OpenFOAM Meshing & Mesh Conversion | 0 | May 31, 2013 12:48 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 09:27 |
