February 5, 2019, 10:44 |
Help with mapFields syntax for large problem
TWB
Rep Power: 19 |
I'm trying to run my simulation from coarse to fine grid. I used to run: mapFields ../"source dir" -consistent -mapMethod interpolate -sourceTime 0.001 which works fine. However now my 3D fine grid is rather large @ 2130x900x150 Using mapFields with 1 processor doesn't seem to work due to large memory req. I'm trying to use either mapFields with parallel source and target or to use mapFieldsPar instead. However, I can't get them to work. I wonder what's wrong with my syntax. For e.g. I use: mapFields -mapMethod interpolate -consistent -sourceDecomposeParDict ../sphere-heat-transfer_80x80_test/system/decomposeParDict -parallelTarget -targetDecomposeParDict system/decomposeParDict -sourceTime 5.000001e-05 ../sphere-heat-transfer_80x80_test or mpirun -n 4 mapFieldsPar ../sphere-heat-transfer_80x80_test/ -parallel -sourceTime 5.000001e-05 In the 1st, I got a seemingly correct output: Source mesh size: 6400 Target processor 0 mesh size: 2065 Mapping fields for time 5.000001e-05 interpolating wallHeatFlux interpolating p interpolating T interpolating U Target processor 1 mesh size: 2066 Mapping fields for time 5.000001e-05 interpolating wallHeatFlux interpolating p interpolating T interpolating U Target processor 2 mesh size: 2030 Mapping fields for time 5.000001e-05 interpolating wallHeatFlux interpolating p interpolating T interpolating U Target processor 3 mesh size: 2031 Mapping fields for time 5.000001e-05 interpolating wallHeatFlux interpolating p interpolating T interpolating U End But there's nothing inside the processor* folders. Can someone guide me? Thanks! |
February 6, 2019, 18:30 |
Luis Eduardo
Rep Power: 15 |
Do you have a source that was run in parallel? I mean, are you trying to map from a reconstructed case to a parallel case? The cases I run have parallel source and target, the command I run in the target path is: Code:
mapFields path/to/source -sourceTime latestTime -parallelSource -parallelTarget -consistent Best Regards, Luis |
February 6, 2019, 23:26 |
TWB
Rep Power: 19 |
Thanks for the help lebc!
I tried your mtd and it seems to work. I need to 1st create the processors' directories by using decomposePar with the same time directory. I just renamed my 0 dir to that same time directory. It ran but I got the error: Source processor 2 Source time: 0.0001 Target time: 0.0001 mesh size: 900 Target processor 0 mesh size: 3600 --> FOAM Warning : From function void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 155 Source patch wall has no faces. Not performing mapping for it. Mapping fields for time 0.0001 interpolating p interpolating T interpolating U Target processor 1 mesh size: 3600 --> FOAM Warning : From function void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 155 Source patch wall has no faces. Not performing mapping for it. Mapping fields for time 0.0001 I also tried another command: mpirun -n 4 mapFieldsPar -consistent -parallel -sourceTime latestTime ../path/to/source for 4 processors. The output are different although there's no error msg. The file size for both are the same but "diff" says they are different in contents. I will have to test to see if either or both works... |
February 6, 2019, 23:41 |
Luis Eduardo
Rep Power: 15 |
I do the same thing, I create a folder with dummy files in the time step I want to map. What is your OF version? I ask because Iḿ using 4.1 and there was a correction of a bug right after I compiled my version, I think I was receiving this kind of messages before. You can check this post (number 5), just to make sure that you have this fix compiled in your version: mapFields Let me know if it works! Best Regards, Luis |
Personalization of mapFields and libsampling - Compilation issues | saimat | OpenFOAM Programming & Development | 3 | June 29, 2016 09:56 |
problem with mapFields and setFields | Ray092 | OpenFOAM Pre-Processing | 1 | December 29, 2015 14:02 |
Problem with CEL syntax for additional variable | rbezerra | CFX | 4 | July 31, 2015 11:47 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
