openfoam ext4.0 and problem in cyclic condition
Old   January 19, 2019, 08:58
Default openfoam ext4.0 and problem in cyclic condition
Hojatollah Gholami
Hgholami is on a distinguished road
Dear all.
I try to model periodic condition in top and down of fluid zone with createPatchDic. I first combine two faces and then use cyclic, but the solver take a error.
my file createPatchDic is :
pointSync true;
// Patches to create.
patchInfo
name elastic;
dictionary
type wall;
constructFrom patches;
patches (elastic1u elastic2u);
name fix;
dictionary
type wall;
patches (fix1u fix2u);
name down //line 47
dictionary
type cyclic;
neighbourPatch top;
transform translational;
separationVector (0 -0.05 0);
patches (top down);
set f0; //line 58
name top
dictionary
type cyclic;
neighbourPatch down;
patches (top down);
set f0;
and the errorr is
Create time
Reading createPatchDict.
Create polyMesh for time = 0
Adding new patch elastic as patch 17 from
type wall;
Adding new patch fix as patch 18 from
type wall;
Moving faces from patch elastic1u to patch 17
Moving faces from patch elastic2u to patch 17
Moving faces from patch fix1u to patch 18
Moving faces from patch fix2u to patch 18
--> FOAM FATAL IO ERROR:
keyword constructFrom is undefined in dictionary "/home/itp/foam/foam-extend-4.0/tutorials/tubes/fluid/system/createPatchDict:atchInfo"
file: /home/itp/foam/foam-extend-4.0/tutorials/tubes/fluid/system/createPatchDict:atchInfo from line 47 to line 58.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
Did anybody have this error and how do you fix it?
Hgholami is offline   Reply With Quote
Old   January 19, 2019, 09:33
Hojatollah Gholami
the problem was due to ";" after the "name top" that added and problem is solved.
Old   February 19, 2019, 11:53
Hojatollah Gholami
Success code
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object createPatchDict;
pointSync false;
patchInfo
name periodic1;
dictionary
type cyclic;
// neighbourPatch top;
// transform translational;
// separationVector (0 -0.05 0);
patches (down top);
set f0;
periodic condition
[Other] Cyclic patch problem! SMartella OpenFOAM Meshing & Mesh Conversion 7 May 6, 2024 09:03
[Commercial meshers] Problem with cyclic boundaries in Openfoam 2.3, mesh import from ICEM Scabbard OpenFOAM Meshing & Mesh Conversion 29 October 6, 2020 22:14
Understanding the cyclic boundary condition leroyv OpenFOAM Running, Solving & CFD 10 May 31, 2020 10:05
Cyclic rotor stator boundary condition problem fairuz OpenFOAM 3 April 26, 2014 01:16
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 13:46
