Inlet and outlet profile are partially positive and negative at the same time |
January 18, 2019, 06:11 |
Loek
Rep Power: 8 |
Dear foamers,
I have questions regarding and inlet profile which is partially negative and partially positive. My model needs to become a horizontal channel (picture of schematics is added below). To limit the amount of gridcells, I am modelling a inifinitely small angle of the channel in the theta direction, practically making it a 2D problem. So now I have the top which is the wall of the channel, the bottom which is the centre of the channel and the left and right are respectively the in- and outlet of the channel and front and back are defined as empty. Eventually I'm going to model flow, masstransfer and kinetics around a bubble. So the profile is kind of funky. The bubble is the reference frame. So I calculate the flowprofile of a liquid through a channel without the bubble via Hagen-Poiseuille and substract the bubble velocity to obtain the flowprofile for a system with a bubble as the frame of reference. When I do this, part of the final flow balance is negative and part is positive. If I try to use the codedFixedValue boundary, I get unphysical results. I haven't heard of another way to induce a profile on a boundary. So my questions here are: Does anybody has any experience with this kind of flow profile input? Is there any other boundary to use to impose a profile on a boundary in which I write an equation? Sincerely, Loek |
negative input for velocity inlet to make an outlet? | Sipher | FLUENT | 1 | June 24, 2015 03:51 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 13:30 |
the static pressure at one outlet is negative? | yuhehuan | Main CFD Forum | 7 | August 15, 2013 22:01 |
Modeling transient negative pressure (suction pressure) in outlet | N_mrtz | FLUENT | 1 | July 18, 2013 21:59 |
Negative pressure but Positive flow? | ashrawage | FLUENT | 2 | February 20, 2012 07:56 |
