January 13, 2019, 15:04 |
Gmsh 4 compatibility with gmshToFoam
#1 | |
Gavin Ridley
Rep Power: 7 |
Hello all,
Gmsh 4 has some nice new capabilities like meshing around STL and constructive solid geometry capability. I'm attempting to test importing this to an OpenFOAM mesh, but it seems some incompatibility exists between the gmsh file and gmshToFoam. In particular, gmshToFoam returns: Quote:
This looks to me like Gmsh 4 has a slightly different ASCII .msh format from what gmshToFoam is used to. If it helps, my gmsh input which runs fine is: Code:
SetFactory("OpenCASCADE"); Box(1) = {-10,-20,-10, 49,100,60}; Delete { Volume{1}; } SetFactory("Built-in"); Merge "dingding.stl"; Surface Loop(1) = {1,2,3,4,5,6}; Surface Loop(2) = {7}; Volume(9) = {2}; Volume(10) = {2,1}; Physical Surface("walls") = {6, 1, 2, 5}; Physical Surface("inlet") = {3}; Physical Surface("outlet") = {4}; Physical Surface("dingding") = {7}; Physical Volume("inside") = {10}; Mesh.CharacteristicLengthMax = 1; Maybe this has to do with the fact that the gmsh mesh is created from meshing an STL surface. Regardless, it's not like the .msh file references the .stl or anything like that. Has anyone seen a message like this before? Otherwise I'll report it as a bug, I suppose. |
January 14, 2019, 14:06 |
Gavin Ridley
Rep Power: 7 |
For anyone encountering this:
NVM, seems this is already reported on the openfoam-plus repository issue tracker. https://develop.openfoam.com/Develop...us/issues/1155 |
[Gmsh] gmshToFoam error depending on export format from Gmsh | lyt7349 | OpenFOAM Meshing & Mesh Conversion | 3 | October 15, 2020 01:06 |
[Gmsh] gmsh or gmshToFoam problem? | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 0 | June 19, 2012 09:52 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 03:28 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
