fluent3DMeshToFoam creates additional boundaries i didnt specify.
Old   January 13, 2019, 10:25
Default fluent3DMeshToFoam creates additional boundaries i didnt specify.
Florian
Archoncomando is on a distinguished road
Hello there!
I'm currently working on simulating a hydrofoil with OpenFOAM. I'm creating a mesh using Ansys workbench and convert it using fluent3DMeshToFoam.
A couple of things confuse me however. When i run the conversion the boundary file contains several conditions i never set. They are named Wall-Volumen-krper for example. In my meshing i only specified the sides of the domain and "part1" however.
I got most of the file structure from the student doing the work mine is based on. Does fluent3dmeshtofoam draw on any files for input other than the mesh file? Maybe i could look those up and see if they're responsible for the additional boundary conditions.
An extra question if any of you have also worked with Ansys meshing for openfoam: When simulating something like a wing my instructions state to remove the wing from the domain by use of a boolean substraction. However it does not state wether to keep the tool body and wether to use the surface of the wing or the internal surfaces of the domain (created by the boolean operation) to define the boundary condition of the part. Anyone got any insight on that?
And help would be greatly appreciated!
Archoncomando is offline   Reply With Quote
ansys 19.2, boundary condition, fluent3dmeshtofoam, meshing
Condensation as an additional variable Clark Griswold CFX 2 April 21, 2012 08:20
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 12:58
GETVAR SUBROUTINE for additional variable in CFX Tuks Main CFD Forum 0 November 8, 2005 07:13
Source terms for additional variable transport eqn Nandini Rohilla CFX 0 February 6, 2004 14:38
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
