December 17, 2018, 05:35 |
Error conversion mesh from UNV to FOAM
Nicola D'Ettole
Rep Power: 7 |
had created a mesh with Salome 8 , butwhen i rin ideasUnvToFoam appear this error 0: inlet is #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/ideasUnvToFoam" #4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #5 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/ideasUnvToFoam" Errore di segmentazione (core dump creato) Wath problem ? regards |
December 17, 2018, 09:23 |
Nicola D'Ettole
Rep Power: 7 |
December 18, 2018, 17:00 |
Solved
Nicola D'Ettole
Rep Power: 7 |
YES IT WORKS.
"create groups from geometry" instead of "create group" is the solution. |
February 26, 2022, 18:14 |
Shif
Rep Power: 4 |
March 4, 2022, 21:49 |
ideasUnvToFoam pipe.unv
Outside North America
Rep Power: 5 |
Hi, I have a problem with grid conversion. When I tried to convert the Unv grid file exported from Salome to a format supported by OpenFoam, it got the following error. Can someone give me a hand?
Thank you! thk@LAPTOP-04QGRRSQ:~/run/cavity$ ls 0 constant logs pipe.unv system thk@LAPTOP-04QGRRSQ:~/run/cavity$ ideasUnvToFoam pipe.unv /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-3bcbaf946ae9 Exec : ideasUnvToFoam pipe.unv Date : Mar 05 2022 Time : 09:31:20 Host : "LAPTOP-04QGRRSQ" PID : 677 I/O : uncollated Case : /home/thk/run/cavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL ERROR: Cannot open file "pipe.unv" From function int main(int, char**) in file ideasUnvToFoam.C at line 679. FOAM exiting |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
