Error running simulation after pre-processing with mapField
Old   November 7, 2018, 23:43
Default Error running simulation after pre-processing with mapField
TWB
quarkz is on a distinguished road
I'm using mapField to create a solution for my coarse grid, obtained from my fine grid. The geometry is exactly the same, from 710x600 to 310x300. My command is:
mapFields ../large_cone_flare_wo_slip_y+=1_kOmegaSST_710x600 -consistent -sourceTime 0.0002000003
The command ended w/o error.
However, when I run my coarse simulation, I got the error:
Create time
--> FOAM Warning :
From function void Foam::Time::setControls()
in file db/Time/Time.C at line 228
Increasing the timePrecision from 6 to 7 to support the formatting of the current time directory 0.0002000003
Create mesh for time = 0.0002000003
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleInternalEnergy;
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib64/libc.so.6"
#3 Foam::heThermo<Foam:siThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::init() at ??:?
#4 Foam::heThermo<Foam:siThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&,
#6 Foam:siThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib64/libc.so.6"
#9 ? at ??:?
[nus03:19923:0] Caught signal 8 (Floating point exception)
==== backtrace ====
2 0x000000000005a42c mxm_handle_error() /var/tmp/OFED_topdir/BUILD/mxm-3.5.3092/src/mxm/util/debug/debug.c:641
3 0x000000000005a59c mxm_error_signal_handler() /var/tmp/OFED_topdir/BUILD/mxm-3.5.3092/src/mxm/util/debug/debug.c:616
4 0x0000000000032510 killpg() ??:0
5 0x0000000000032495 raise() ??:0
6 0x0000000000032510 killpg() ??:0
7 0x00000000002587ac _ZN4Foam8heThermoINS_9psiThermoENS_11pureMixtureIN S_14constTransportINS_7species6thermoINS_12hConstT hermoINS_10perfectGasINS_6specieEEEEENS_22sensible InternalEnergyEEEEEEEE4initEv() ??:0
8 0x000000000018a89e _ZN4Foam8heThermoINS_9psiThermoENS_11pureMixtureIN S_14constTransportINS_7species6thermoINS_12hConstT hermoINS_10perfectGasINS_6specieEEEEENS_22sensible InternalEnergyEEEEEEEEC1ERKNS_6fvMeshERKNS_4wordE( ) ??:0
9 0x00000000001a21b5 _ZN4Foam9psiThermo27addfvMeshConstructorToTableINS _11hePsiThermoIS0_NS_11pureMixtureINS_14constTrans portINS_7species6thermoINS_12hConstThermoINS_10per fectGasINS_6specieEEEEENS_22sensibleInternalEnergy EEEEEEEEEE3NewERKNS_6fvMeshERKNS_4wordE() ??:0
10 0x000000000014d67e _ZN4Foam9psiThermo3NewERKNS_6fvMeshERKNS_4wordE() ??:0
11 0x00000000004243d7 main() ??:0
12 0x000000000001ed1d __libc_start_main() ??:0
13 0x0000000000424059 _start() ??:0
I tried to change the mapMethod to interpolate but I got the same error.
Can anyone suggest why this is happening?
quarkz is offline   Reply With Quote
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 03:47
mesh from Workbench Simulation to Cfx Pre? Dai CFX 6 November 11, 2006 13:19
Automatic post processing of Transient simulation Aziz CFX 2 June 24, 2005 15:37
Post processing Combustion simulation Newbie Main CFD Forum 0 April 14, 2004 12:08
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
