Radiation in vacuum using viewFactor
Old   October 29, 2018, 11:56
Question Radiation in vacuum using viewFactor
Jessica Bell
Jessica6 is on a distinguished road
Hello everyone!
I'm working on my first case and it's main goal is to evaluate the heat load made by radiation.
In the analysis, there are two surfaces with significantly different temperaures. The warmer surface should emit heat to the colder one by radiation phenomen. The whole system is placed in the vacuum so no convection occurs. Those surfaces are not connected anyhow so there is no conduction.
For this purpose I decided to use chtMultiRegionFoam and viewFactors radiation model.
The results I got is qr = 1.2*10^(-38) and viewFactorField with values way above 1, which are obviously wrong.
Playing with values in viewFactorsDict made no difference.
Now my suspicion is that the program doesn't work for radiation because there is no media in between the surface. Is this can be a reason? What are the others possible reasons?
Have anyone tried to deal with radiation in vacuum?
Cheers,
Jessica
Jessica6 is offline   Reply With Quote
multiregionheater, radiation simulation, radiationmodel, vacuum chamber, view factors
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation Zeppo OpenFOAM Running, Solving & CFD 16 May 18, 2017 19:04
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 11:29
radiation modeling in vacuum mirko OpenFOAM Programming & Development 7 May 20, 2016 09:31
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
