October 18, 2018, 21:39 |
fvOption - pressureGradient
#1 | |
Guilherme
Rep Power: 10 |
I'm doing a cyclic domain simulation. I'm using OpenFOAM version 5.0 and I'm not sure how to generate a pressure gradient in my domain. I know the fvOption tool and it has worked BUT I believe it has not been very efficient. My results in LES are not very interesting when compared to what I get in Fluent and I'm '' giving '' credits to fvOption. Quote:
I do not know if I made the best possible configurations for my case, but this 'meanVelocityForce' is the only option for this version of OF. Would it be interesting for me to compile the 'pressureGradientExplicitSource' used in previous versions? Is there any option for swak4Foam? I tried using 'vectorFixedValueConstraint' ... but apparently the newer versions of this tool do not have this option. Is there any way I can set the value of my pressure gradient, similar to the way I do in Fluent? There my gradient are dp/dz = -36. Can I do this in swak4Foam? I have attached some of my results ... my goal is to approximate the curves obtained in Fluent (in both software is using the same mesh). Thanks |
cyclic bc, fvoption, pressure gradient, swak4foam |
[swak4Foam] swak4foam for fe40: fvOption library don't compile? | jf_vt | OpenFOAM Community Contributions | 7 | August 10, 2023 03:00 |
reactingFoam fvOption ignition | khalifa | OpenFOAM Programming & Development | 8 | January 6, 2019 18:45 |
fvOption interpolation scheme | aghsin | OpenFOAM Running, Solving & CFD | 0 | June 25, 2016 09:01 |
presGradient in fvOption | bargiola | OpenFOAM Running, Solving & CFD | 0 | May 25, 2015 04:39 |
pressureGradient dictionary | dav.dap83 | OpenFOAM Pre-Processing | 5 | January 11, 2015 17:48 |
