October 18, 2018, 15:24 |
wave simulation
Behsam
Rep Power: 10 |
Hello
i need to simulate a wave tank and i tried to do the tutorial in openfoam 5 which is solving by interfoam but i am new with CFD and openfoam i dont know what to do? Thank you for your answers |
October 29, 2018, 06:05 |
Zander Meiring
Rep Power: 8 |
Depending on the geometric complexity and level of detail, you can skip the need for CFD and consider just solving the wave equation (https://en.wikipedia.org/wiki/Wave_equation).
If CFD truly is needed, the basics should be covered in the interFoam tutorial. The steps are as always: determine a domain, mesh it, pick models, decide on boundary conditions and pick a solver. Then make sure the solver converges to a solution, then post-process. Just asking how to do it makes it very difficult to help you, because nobody else understands the problem. If you want to pose the problem and ask for a complete solution; consider a consulting firm. If you're stuck on one of the steps described above, look at tutorials and try to learn what's needed. Still stuck; pose a detailed question here and hope someone can help you. |
[waves2Foam] A 2D wave tank simulation suffering from wave reflection | gautami | OpenFOAM Community Contributions | 5 | July 24, 2019 08:39 |
Pulse Wave Velocity calculation from FSI simulation | DamR | FLUENT | 0 | January 5, 2017 03:19 |
Nozzle shock wave obtained from FLUENT simulation | aerograce | FLUENT | 0 | December 25, 2016 02:43 |
Simulation of Wave generation in a tank | dolcevitak | FLUENT | 0 | November 22, 2013 22:15 |
5th order wave simulation | Lukan | CFX | 3 | June 5, 2012 20:26 |
