October 8, 2018, 09:28 |
Non uniform viscosity
Massachusetts
Rep Power: 11 |
Hello everybody,
I would like to know how to define an initial non uniform viscosity without changing the solver but defining it in transportProperties file. I calculated the turbulent viscosity from a simulation and I want to use it in a new simulation, but I would like the new simulation to not change the viscosity. In practice I want to use the so called frozen turbulence. Can I do this only from the transportProperties file or Should I change the solver? Thanks for help |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
rSF: p divergence in combustor (wt negative value) | zonda | OpenFOAM Pre-Processing | 4 | April 10, 2018 07:59 |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 11:44 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 15:16 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 08:32 |
