Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 |
October 5, 2018, 17:22 |
Hüseyin Can Önel
Rep Power: 7 |
I am using the following script for mesh generation only. Want to run snappyHexMeshan topoSet in parallel:
nProc=32 cp -rf 0.org/ 0/ blockMesh &> log.blockMesh decomposePar &> log.decomposePar mpirun -np $nProc snappyHexMesh -parallel -overwrite &> log.snappyHexMesh mpirun -np $nProc topoSet -parallel &> log.topoSet # reconstructParMesh -constant &> log.reconstructParMesh Code:
paraFoam -case processor2 Code:
mpirun -np $nProc pimpleFoam -parallel &> log.pimpleFoam Code:
[2] --> FOAM FATAL IO ERROR: [2] Cannot find patchField entry for procBoundary2to7 [2] [2] file: /cfd/honel/OpenFOAM/honel-5.x/axialFlowTurbineAL_NREL5MW/processor2/0/p.boundaryField from line 26 to line 85. [2] [2] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [2] in file /cfd/honel/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191. [2] FOAM parallel run exiting Code:
ls -d processor* | xargs -i cp -r 0.org/* ./{}/0/ $1 |
running rhoCentralFoam in parallel: cannot find patchField entry for procBoundary | hbrist7 | OpenFOAM | 6 | March 27, 2024 06:11 |
Cannot find patchField entry for wall???? | Dream | OpenFOAM | 5 | October 14, 2020 23:27 |
[blockMesh] FOAM FATAL IO ERROR_Cannot find patchField entry | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 2 | January 21, 2016 08:51 |
[Other] 'Cannot find patchField entry for outlet' | cesarjets | OpenFOAM Meshing & Mesh Conversion | 1 | November 25, 2013 00:29 |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 10:22 |
