Negative initial temperature error (chtMultiRegionFoam)
Old   September 14, 2018, 11:06
Exclamation Negative initial temperature error (chtMultiRegionFoam)
jebin george
jebin is on a distinguished road
I am fairly new to OpenFoam using version 6. I am trying to solve the heat transfer between a heatsink with heat source at the bottom and air traveling through the pipe in which only the heat sink is exposed.
I am using chtMultiRegionFoam solver. Split the mesh into two regions and created cellzones.
I gave the thermophysical properties to both heatsink and air and also defined the boundary conditions and the contact boundary as compressible::turbulentTemperatureCoupledBaffleMix ed.
Using RAS model for turbulence properties of air.
Initial temperature of air is 300k and that of heat sink is 273K but I am getting very low values of about -206k
I used fvschemes and fvsoultion from tutorial/heatTransfer/chtMultiRegionFoam/multiregionheater for both separately.
When I try to solve it, its showing "Negative initial temperature T0: -206.172"
and is exiting at 2.5 s while solving the solid
The error message is:
Solving for fluid region waterCellSet
DILUPBiCGStab:  Solving for Ux, Initial residual = 0.0201238, Final residual = 0.000422419, No Iterations 1
DILUPBiCGStab:  Solving for Uy, Initial residual = 0.0189649, Final residual = 0.000425249, No Iterations 1
DILUPBiCGStab:  Solving for Uz, Initial residual = 0.00718987, Final residual = 0.000186804, No Iterations 1
DILUPBiCGStab:  Solving for h, Initial residual = 0.00431549, Final residual = 0.000122464, No Iterations 1
Min/max T:-206.151 339.013
GAMG:  Solving for p_rgh, Initial residual = 0.0455872, Final residual = 0.000385342, No Iterations 2
time step continuity errors : sum local = 0.000534267, global = 8.44534e-05, cumulative = 8.44534e-05
Min/max rho:1.25 1.25
DILUPBiCGStab:  Solving for epsilon, Initial residual = 0.00599105, Final residual = 8.33063e-05, No Iterations 1
DILUPBiCGStab:  Solving for k, Initial residual = 0.0191864, Final residual = 0.000366755, No Iterations 1
Solving for solid region heaterCellSet
DICPCG:  Solving for h, Initial residual = 0.738924, Final residual = 7.06039e-07, No Iterations 32
--> FOAM FATAL ERROR:
    From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::heSolidThermo<Foam::solidThermo, Foam::pureMixture<Foam::constIsoSolidTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#3  Foam::heSolidThermo<Foam::solidThermo, Foam::pureMixture<Foam::constIsoSolidTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:?
#4  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
Aborted (core dumped)
I suspect it might be some error with defining air as I am getting negative values in the result.
The Temp conditions I gave for air is given:
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 300;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 300;
    outlet
        type            inletOutlet;
        value           uniform 300;
        inletValue      uniform 300;
    wall-domain
        type            zeroGradient;
    default_wall
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        value           $internalField;
        Tnbr            T;
        kappaMethod     fluidThermo;
and that for solid is :
internalField   uniform 273;
boundaryField
    base
        type            fixedValue;
        value           uniform 273;
        inletValue      uniform 273;
    sinkbody
        type            zeroGradient;
    wall-domain
        type            zeroGradient;
    default_wall
        value           uniform 273;
        Tnbr            T;
        kappaMethod     solidThermo ;
the fvScheme for air is:
ddtSchemes
    default        steadyState;
gradSchemes
    default         Gauss linear;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;
    div(phi,h)      bounded Gauss upwind;
    div(phi,e)      bounded Gauss upwind;
    div(phi,K)      bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear limited corrected 0.33;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited corrected 0.33;
The fvScheme for solid is:
ddtSchemes
    default Euler;
gradSchemes
divSchemes
    default         none;
laplacianSchemes
    default             none;
    laplacian(alpha,h)  Gauss linear corrected;
    default         linear;
snGradSchemes
    default         corrected;
Can somebody please explain to me what I have done wrong
File Type: jpg case_setup_with_heatsink_domainwall.jpg (19.2 KB, 149 views)
jebin is offline   Reply With Quote
Old   September 14, 2018, 16:49
Peter Hess
peterhess is on a distinguished road
Your ddt shemes for fluid and solid are different...
For fluid you have steady state and for solid you have euler!
I am not sure if this is relevant or could cause such a problem. Test this and see what happens.
Post the case please.
peterhess is offline   Reply With Quote
Old   September 15, 2018, 02:33
Default case setup without polymesh directory
jebin george
Here is the case setup. I could not include the polymesh directory because the case exceeded the upload limit. Do not mind that air casesetup is called watercellset
Old   September 15, 2018, 02:40
jebin george
Thank You for replying.
I changed ddt schemes for solid and air to steady state and the temperature drop in error reduced to -7k. SO its probably the error of choosing the wrong schemes. I have uploaded the case setup. I do not have much knowledge in choosing the appropriate schemes. Please look into it and suggest the appropriate schemes for each part.
Old   September 15, 2018, 03:02
Peter Hess
Hi!
Well, by problems with the setups it is always a good idea to use the default setup.
Simply copy the setup (i.e. fvSchemes and fvSolution) from the working tutorial and use them in your case.
If it works, then compare the difference to find the cause.
There is no mesh in the case you uploaded.
The mesh is needed to run the case and test the progress.
Upload a case with mesh setup please.
Regards
Peter
Old   September 15, 2018, 03:38
Peter Hess
I used the fvSchemes and fvSolution from your case for both solid and fluid regions in an example case that I have...
I replaced my fvSchemes and fvSolution with those from your case.
The case (my case) works with your fvSchemes and fvSolution fine.
The problem you are facing is somewhere else!
What about the pressure?
Change p_rgh from 0 to 1e5!
p_rgh should look like this:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0/waterCellSet";
object p_rgh;
dimensions [ 1 -1 -2 0 0 0 0 ];
internalField uniform 1e5;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 1e5;
wall-domain
type zeroGradient;
default_wall
type fixedFluxPressure;
value uniform 1e5;
wall_domain
value uniform 1e5;
Regards
Peter
Old   September 15, 2018, 06:43
jebin george
Thank you for taking your time to help me.
I have included the case with the mesh file in the link. https://drive.google.com/open?id=1jf...nOUshYzvDdiK8J
Can you please run it to see the problem, If I defined the boundaries wrong. Also what does ".*" mean. Am i supposed to solve using chtMultiRegionSimpleFoam.
Regards
Jebin
Old   September 15, 2018, 07:23
Peter Hess
".*" means apply for all bouandries independent of the name...
In OF6.0 there is no chtMultiRegionSimpleFoam anymore. It has been merged with chtMultiRegionFoam.
By the way, the mesh quality in the case you uploaded is very poor. You need to fix this!
And now to the divergence problem...
Add the folllowing lines to the bottom of controlDict:
maxCo 1; //This limits courant number going higher than 1
maxDi 100; //This limits the diffusity going higher than 100
adjustTimeStep yes; //This let the time steps (deltaT) you defined as 0.1 to be modified to hold maxCo and maxDi
The default deltaT = 0.1 is very high and the courant number becomes very high, since your simulation defined to be transient. You need to reduce it or make it automatic controlled applying the changes I added here.
At least the simulation runs now without any problems...
The file should looks like this:
| \\ / O peration | Version: v1806 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application chtMultiRegionFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 100;
deltaT 0.1;
writeControl adjustableRunTime;
writeInterval 5;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
maxCo 1;
maxDi 100;
adjustTimeStep yes;
To make the simulation steady state you need to do the following:
- For all solid regions in your simulation use fvSchemes and fvSolution from here:
/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeaterRadiation/system/heater/
- For all fluid regions in your simulation use fvSchemes and fvSolution from here:
/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeaterRadiation/system/bottomAir/
Those shemes and solver setups are made for steady state!
Regards
Peter
Old   September 15, 2018, 14:45
jebin george
Thank you sir for giving me the directions.
Right now, I am not facing the initial temperature error and am running the simulation.
Old   September 16, 2018, 03:18
jebin george
This is showing the initial temperature as before
I wanted to obtain a temperature profile on the heat sink walls which is at 273k by the flow of air over it whose inlet temperature is 300k. Right now, I am only getting the air to cool to a lower temperature from 300k because of the heatsink .
The temperature profile is formed by conduction of heat from air into the heat sink. This was validated from an ansys fluent simulation. Do you know of any way I can include this by changing the boundary conditions.
Old   September 16, 2018, 04:26
Peter Hess
The pressure p defined in the internalField in:
/0/waterCellSet/p
need to be changed from 0 to 1e5!
This will solve the divergence problem in steady state case you are facing.
This change is a good idea for both situations transient and steady state...
Old   September 17, 2018, 07:31
jebin george
The case setup is working in steady state now.
During solving, the temperature on the surface of the heatsink fin surface is only rising to 275K (from being at 273k initially) when exposed to air of 300k in a time span of 45 seconds.
I increased the air temperature to 500k but still the heatsink fins are at 275k. In a ansys simulation recreating the conditions, the temperature of the heatsink after post-processing was more than 280k.
Is there a reason as to the temperature of heatsink stopping at 275k or if i simulate for a longer time will it rise to higher temperature ?
Old   September 17, 2018, 07:58
Peter Hess
To compare the results of openFoam and Fluent, you need to be sure that all parameters are identical. Especially the boundaries conditions.
There are many reasons to get different results using openFoam and Fluent.
In my opinion, I would say that having 275 K on the surface is possible, cause you have very high thermal conductivity in the solid and constant temperatur at the base 273 K! 2 K difference between the base and the fins are in my opinion right!
Are Fluent results right and plausible?
I do not confirm that. The steady state case with 500 K at the inlet results about 285 K at the fins!
See attached file!
Old   September 19, 2018, 03:06
jebin george
Thank you for doing the simulation. Was it the same case setup I uploaded? How long was the simulation for?
Old   September 19, 2018, 04:10
Peter Hess
Yes, your case.
I just changed the following:
- making the case steady state (as described above)
- changing internalField p = 1e5 (fluid!)
- changing internalField p_rgh = 1e5
- changing the temperature at the inlet to 500 K
- adding the 3 lines for controlling the time steps, as described above (the simulation works as steady state without this step!)
Those actualy the necessery steps I made, as I remember...
I run the simulation in parallel.
I cant say how much time I needed. I already deleted the simulation. Anyway, about 4 or 5 minutes, then the mesh size is very small.
In about 600 iterations I reached convergence. The simulation run 1000 iterations then I stopped manually!
By the way, I still dont like the mesh. 2 or 3 cells between the fins is unacceptable for me...
Regards
Peter
Old   September 19, 2018, 10:12
jebin george
I am not using a good mesh now because I am running the simulation on my laptop in a virtual box with only two processors.
So its took about 2hrs for me to simulate 10 seconds because of very small time steps.
When i tried using good mesh, the system froze which is why i am sticking to poor mesh.
Right now, I am learning openFoam as part of a internship I am doing.
Once I am capable to do the simulation on my own, I will be using a server to do the simulation
Also how can I see the graph? Which commands should i use?
I also wanted to know if Salome software can create named section and can be exported as .msh file?
Old   September 19, 2018, 11:05
Peter Hess
To plot the residuals you need to do the following:
- install gnuplot (if not already installed)
- copy the file attached to the simulation folder
- start the simulation by typing:
chtMultiRegionsFoam > log
This will write the simulation iterations progress to a log file called log instead of the terminal!
- in a new terminal type:
gnuplot Plot.txt
I cant talk about Salome, cause I dont use it!
Regards
Peter
File Type: txt Plot.txt (952 Bytes, 57 views)
Old   September 24, 2018, 08:35
jebin george
Hi Peter,
I created a new case with four heat sinks arranged in serial in air domain with same conditions as the previous case. I solved it using one core processor.
- Then, I tried decomposing it using the decomposeParDict but its showing an error--
fileName::stripInvalid() called for invalid fileName /home/jebin-helyx/Desktop/test2/airdomainwith4heatsinks--steady
For debug level (= 2) > 1 this is considered fatal
-I am using the steady state solver and the same values as before.
-The case setup is
https://drive.google.com/file/d/16Vk...ew?usp=sharing
-Can you please check the case file and tell me what I have done wrong? Also do I have to setup any file after it is decomposed, to run the 'mpirun -np ....' command and get the result.
Disclaimer- The mesh is extremely poor. I created this only to learn the decomposition and reconstruction.
Regards
Jebin
Old   September 24, 2018, 10:03
Peter Hess
Changing the name of the Folder from:
airdomain with 4heatsinks--steady
To
airdomain_with_4heatsinks--steady
Solves the problem!
Spaced in the name are not allowed
Regards
Peter
Old   September 24, 2018, 12:55
jebin george
Wow! That was simple!
Thank you for clearing that out. I couldn't have reached here without your help, sir.
I divided the case between two processors by running the command decomposePar
-The 0 folder in each processors only have cellToRegion file.
-Do I need to add any files or can I directly run the command " mpirun -np 2 chtMultiRegionFoam" ?
-Will the time required for processing decrease if I increase the number of cores ?
Regards
Jebin
chtmultiregionfoam, error, negative initial temp
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
