Owner list and its relation with the total number of cells |
September 12, 2018, 15:23 |
Rep Power: 8 |
Hello Foamers,
I am actually stack on a wired problem and I appreciate your help . I have generated a tetra mesh inside a cube in the classical openFOAM format. I was looking into the file "owner" and surprising I have noted this: the maximum owner index is not equal to the total number of cells... For example the number of cells is 2750 while the maximum value in the owner list is 2746. How can this be possible? Am I missing something? Thank you very much! |
September 27, 2018, 03:21 |
Tobias Holzmann
Rep Power: 52 |
interesting point. I never checked it out. Can you provide your case? I would like to know what is going on there. For that purpose, I need the OpenFOAM case.
Keep foaming, Tobias Holzmann |
September 27, 2018, 04:55 |
Rep Power: 8 |
Hi Tobi, thank you very much for your interest!
Working a bit on this I have find out that "usually" for hexa meshes the maxium index in owner list is also the total number of cells. However, in general, this might be not the case (e.g. doing a mesh in a cube using only tetra)! Why? Well, because if you think a bit about this, you can build one element using faces belonging only to neighbour cells and this depends on how your mesher export the mesh in OF format. Thus the answer is (and I am 99% sure) that the total number of cells is: max(a,b), where a=max(owner) and b=max(neighbour). |
September 27, 2018, 06:36 |
Tobias Holzmann
Rep Power: 52 |
I already made a sketch too, and it should be clear that
Because, based on fundamental analysis, each numerical cell should have a neighbor, either way, it is hex, tet, poly, or any other volume type. Therefore, - for me - the only possibility is to have separated cells or a configuration I am not aware right now. In your example, there are two cells which do not have any neighbor (or maybe I am misinterpreting the files), and I would like to visualize and analyze the mesh in order to know what is going on and why there are two entries missing. Moreover, I know that, e.g., snappy makes some crazy cells sometimes. Even though you have your analysis and statement, there is 1 % of uncertainty Maybe the mismatch is related to the declaration of owner/neighbor (should be related to the normal surface vector)
