cyclicAMI bc with two neighbouring patches
Old   August 11, 2018, 05:22
Default cyclicAMI bc with two neighbouring patches
zeshan
Thecomebackkid is on a distinguished road
hi all,
I have a case with domain and two separate rotating mrfs within it. I want to use cyclicAMI bc for interfaces:
mrf1 to domain
mrf2 to domain
domain to mrf1 and mrf2.
In order to I would like to know if I can specify two neighbouring patches somehow?
boundaryField
    DOMAIN
        type            cyclicAMI;
        inGroups        1(cyclicAMI);  ///also what is this for?
        matchTolerance  0.1;
        //transform       rotational;
        neighbourPatch  mrf1, mrf2 ------<< here is my problem it wont take two?
        rotationAxis    (0 0 1);
        rotationCentre  (0 0 0);
        nFaces          1628;
        startFace       171370;
does anyone know how I can do this?
thanks,
Zeshan
Thecomebackkid is offline   Reply With Quote
Old   August 11, 2018, 10:30
anonymous
simrego is on a distinguished road
Hi!
I don't know if this is the same for cyclicAMI but as i know for example in CHT if you try to create an interface like this, AMI will complain.
Try to create two different patches in the domain like this:
couple domain1 with mrf1 and domain2 with mrf2.
It should works then.
simrego is offline   Reply With Quote
Old   August 11, 2018, 11:10
zeshan
Originally Posted by simrego View Post
Hi!
hey thanks for the reply, I will try that out...and come back to you.
Old   August 16, 2018, 05:29
zeshan
Hi!
Hi i am still having problems. i have tried the way you said but now i get a error with the AMI bc's
$ pimpleFoam.exe
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
/*   Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt   *\
|  Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com   |
Build  : 5.x-963176928289
Exec   : C:/PROGRA~1/BLUECF~1/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin/pimpleFoam.exe
Date   : Aug 16 2018
Time   : 09:22:09
Host   : "SWNPC5003"
PID    : 2244
I/O    : uncollated
Case   : C:/PROGRA~1/BLUECF~1/ofuser-of5/run/new/test/DOMAIN
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM Warning :
    From function virtual Foam::label Foam::cyclicAMIPolyPatch::neighbPatchID() const
    in file AMIInterpolation/patches/cyclicAMI/cyclicAMIPolyPatch/cyclicAMIPolyPatch.C at line 720
    Patch GEARDVN specifies neighbour patch INTERFACE
 but that in return specifies GEARDRV
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Reading field p
AMI: Creating addressing and weights between 33370 source faces and 17392 target faces
--> FOAM Warning :
    From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>]
    in file ./AMIInterpolation/AMIInterpolation/AMIMethod/AMIMethod/AMIMethod.T.C at line 57
    Source and target patch bounding boxes are not similar
    source box span     : (0.0213595 0.0384635 0.0192317)
    target box span     : (0.0213595 0.0213595 0.0192317)
    source box          : (0.263241 0.215276 0.000925333) (0.2846 0.25374 0.020157)
    target box          : (0.263241 0.23238 0.000925333) (0.2846 0.25374 0.020157)
    inflated target box : (0.261451 0.23059 -0.000865135) (0.286391 0.25553 0.0219475)
--> FOAM FATAL ERROR:
Unable to set source and target faces
    From function void Foam::faceAreaWeightAMI<SourcePatch, TargetPatch>::setNextFaces(Foam::label&, Foam::label&, Foam::label&, const boolList&, Foam::labelList&, const Foam::DynamicList<int>&, bool) const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; Foam::label = int; Foam::boolList = Foam::List<bool>; Foam::labelList = Foam::List<int>]
    in file ./AMIInterpolation/AMIInterpolation/AMIMethod/faceAreaWeightAMI/faceAreaWeightAMI.C at line 287.
FOAM aborting
Generating stack trace...
Backtrace:
        ZN10StackTraceC1Ev [0x705c1465+0x25]
                 module: C:\PROGRA~1\BLUECF~1\ThirdParty-5.x\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll
        ZN4Foam5error10printStackERNS_7OstreamE [0x931c88+0x218]
                 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll
        ZN4Foam5error5abortEv [0x6e5b5d+0x12d]
        ZN4Foam17faceAreaWeightAMIINS_14PrimitivePatchINS_4faceENS_7SubListERKNS_5FieldINS_6VectorIdEEEES6_EESA_E14calcAddressingERNS_4ListINS_11DynamicListIiLj0ELj2ELj1EEEEERNSC_INSD_IdLj0ELj2ELj1EEEEESG_SJ_ii [0x63318052+0x1e2]
                 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libmeshTools.dll
        ZN4Foam17faceAreaWeightAMIINS_14PrimitivePatchINS_4faceENS_7SubListERKNS_5FieldINS_6VectorIdEEEES6_EESA_E9calculateERNS_4ListINSC_IiEEEERNSC_INSC_IdEEEESF_SI_ii [0x63318cb4+0xf4]
        ZN4Foam16AMIInterpolationINS_14PrimitivePatchINS_4faceENS_7SubListERKNS_5FieldINS_6VectorIdEEEES6_EESA_E6updateERKSA_SD_ [0x6330e6a9+0x339]
        ZN4Foam16AMIInterpolationINS_14PrimitivePatchINS_4faceENS_7SubListERKNS_5FieldINS_6VectorIdEEEES6_EESA_E20constructFromSurfaceERKSA_SD_RKNS_7autoPtrINS_17searchableSurfaceEEE [0x6330d83a+0x5ba]
        ZNK4Foam18cyclicAMIPolyPatch8resetAMIERKNS_16AMIInterpolationINS_14PrimitivePatchINS_4faceENS_7SubListERKNS_5FieldINS_6VectorIdEEEES7_EESB_E19interpolationMethodE [0x632cb8ff+0x71f]
        ZNK4Foam18cyclicAMIPolyPatch3AMIEv [0x632c6203+0x93]
        ZNK4Foam18cyclicAMIPolyPatch24applyLowWeightCorrectionEv [0x632c62a9+0x29]
        ZNK4Foam21cyclicAMIFvPatchFieldIdE19patchNeighbourFieldEv [0x6651da40+0x80]
                 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libfiniteVolume.dll
        ZN4Foam19coupledFvPatchFieldIdE8evaluateENS_8UPstream10commsTypesE [0x660bf6da+0x3a]
        ZN4Foam21cyclicAMIFvPatchFieldIdEC1ERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE [0x660db52b+0x18b]
        ZN4Foam12fvPatchFieldIdE31adddictionaryConstructorToTableINS_21cyclicAMIFvPatchFieldIdEEE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE [0x660172c9+0x39]
        (No symbol) [0x407ef6]
                 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\pimpleFoam.exe
        (No symbol) [0x41098c]
        (No symbol) [0x40f8e6]
        (No symbol) [0x40fb4c]
        (No symbol) [0x41193c]
        (No symbol) [0x44eda4]
        (No symbol) [0x4013f7]
        (No symbol) [0x40152b]
        BaseThreadInitThunk [0x76f359cd+0xd]
                 module: C:\Windows\system32\kernel32.dll
        RtlUserThreadStart [0x7709383d+0x1d]
                 module: C:\Windows\SYSTEM32\ntdll.dll
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
is there anyway to resolve this issue?
here's my boundary file:
FoamFile
    version     2.0;
    format      binary;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
10
    INLET
        type            patch;
        nFaces          1860;
        startFace       661476;
    OUTLET
        type            patch;
        nFaces          1842;
        startFace       663336;
    BR
        type            patch;
        nFaces          4131;
        startFace       665178;
    BL
        type            patch;
        nFaces          4131;
        startFace       669309;
    UP
        type            patch;
        nFaces          4830;
        startFace       673440;
    LW
        type            patch;
        nFaces          5072;
        startFace       678270;
    INTERFACE
        type            cyclicAMI;
        matchTolerance  0.1;
        transform       noOrdering;
    rotationAxis ( 0 0 1 );
    rotationCentre ( 0.273932 0.234316 0.0103284 );
        neighbourPatch  GEARDRV;
        nFaces          33370;
        startFace       683342;
    GEARDRV
        type            cyclicAMI;
        matchTolerance  0.1;
    rotationCentre ( 0.273932 0.243851 0.0103284 );
        neighbourPatch  INTERFACE;
        nFaces          17392;
        startFace       716712;
    GEARDVN
        type            cyclicAMI;
        matchTolerance  0.1;
    rotationCentre ( 0.273932 0.224781 0.0103284 );
        nFaces          15816;
        startFace       734104;
    INTERFACE
type cyclicAMI
        matchTolerance  0.1;
        neighbourPatch  GEARDVN;
nFaces 33370;
startFace 683342;
Old   August 16, 2018, 08:40
Robert
RobertHB is on a distinguished road
Originally Posted by Thecomebackkid View Post
boundaryField
    DOMAIN
        type            cyclicAMI;
        matchTolerance  0.1;
        nFaces          1628;
        startFace       171370;
Don't bother with the content of the boundary file. You will not have to change it manually.
inGroups 1(cyclicAMI); - OpenFoam groups patches of a similar type. Your DOMAIN patch is part of one group, namely cyclicAMI
neighbourPatch mrf1, mrf2 - In your blockMeshDict, when creating your domain, you have to give a neighbourPatch to each cyclic patch. E.g. if you have an inlet and an outlet connected by a cyclic boundary condition, you would write for the inlet patch neighbourPatch outlet; and for the outlet patch neighbourPatch inlet;.
As for you latest error:
i'd guess its because your two cyclic patches are not lining up propperly. Maybe the is because you commented out the transform command.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   August 16, 2018, 10:12
zeshan
As for you latest error: i'd guess its because your two cyclic patches are not lining up propperly. Maybe the is because you commented out the transform command.
THANKS FOR YOUR REPLY.....I will check this later and may come back to you.
cyclicami; mrf
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 09:19
cyclic / cyclicAMI boundary conditon - ICEM Mesh cyln OpenFOAM Running, Solving & CFD 0 November 7, 2017 16:26
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
CyclicAMI issues vabishek OpenFOAM Pre-Processing 1 December 6, 2015 17:37
problem with cyclicAMI and wall distance Maff OpenFOAM Bugs 5 August 14, 2014 15:41
