July 18, 2018, 07:55 |
Creating faceSet on stl-surface
Marian
Hello everyone,
I'm looking for a way to create an faceSet on an arbitrary triangulated surface from an existing mesh for foam-extend 3.1. I need this for some evaluation, therefore the surface must not depend on patches. Are there any tools which enable this? Thanks |
April 14, 2019, 10:53 |
#2 | |
Any updates on that?
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
April 17, 2019, 03:43 |
Gareth
Rep Power: 16 |
[snappyHexMesh] Creating stl file for snappyHexMesh from xyz coordinates | Vignesh2508 | OpenFOAM Meshing & Mesh Conversion | 2 | April 25, 2017 09:43 |
Scale Surface | CellZone | OpenFOAM Post-Processing | 1 | September 2, 2016 09:29 |
[Gmsh] Extrude stl surface for building a prismatic layer | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 12 | April 21, 2016 17:54 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
