twoPhaseEulerFoam - particle diameter distribution |
Rep Power: 8 ![]() |
Hi Foamers,
i'm using twoPhaseEulerFoam and i would like to use some different diameters for my particles in the same field. Is there a modell for a normal distribution instead of the diameterModel constant? I'm initializing my particle field with setFields - maybe i can create some more fields with different diameter? Thank you ![]() |
krishnan
Looks like you need population balance modelling. Look at OpenFoam-dev and OF-6 where the method of classes are implemented in reactingTwophaseEulerFoam
ssa
Rep Power: 7 ![]() |
you can use normal distribution in lagrangian solvers, (MPPICFoam, DPMFoam). I am using it in OF 5.0.
diameter, diametermodel, twophaseeulerfoam |
general type in particle distribution model | ethan oh | OpenFOAM Running, Solving & CFD | 1 | February 10, 2021 03:48 |
size distribution models in OpenFOAM 4.x | minzhang | OpenFOAM Running, Solving & CFD | 1 | March 30, 2018 18:10 |
Particle Distribution in Plasma Freejet (at high temperature) | CFD Germany | Siemens | 0 | November 20, 2017 04:48 |
Diameter distribution, Search for options ?! | souria | FLUENT | 0 | January 22, 2016 08:38 |
MULTIPHASE: random particle diameter | UDS_rambler | FLUENT | 0 | March 22, 2013 11:33 |
