July 3, 2018, 14:01 |
internalField vs setFieldsDict
Rep Power: 12 |
I am a bit confused on the use of internalField versus setFieldsDict. If I specify the internalField (whether uniform or a vector list), do I still need a setFieldsdDict? In my particular case, I am running mesh refinement for a transient case, so the initial internalField (for the subsequent mesh refinements) is defined using mapFields and the previous coarser solution. Do I need to define a setFieldsDict as well for this finer run? Thanks Last edited by jxs832; July 3, 2018 at 14:03. Reason: typos |
July 4, 2018, 04:27 |
Gerhard Holzinger
Rep Power: 28 |
internalField contains the values of the field for each cell. Alternatively, you can specify uniform values.
If you want to start your simulation with non-trivial initial conditions, then you can use:
Using setFields or mapFields is optional, so you only need the [map|set]FieldsDict file when you use corresponding pre-processing tool. If you directly write your non-uniform values into the internalField list, then you do not need to use any pre-processing tool. However, this list has as many entries as the mesh has cells. |
initial conditions., internalfields, setfieldsdict |
internalField condition | mchehab2 | OpenFOAM Running, Solving & CFD | 14 | November 10, 2022 14:28 |
internalField nonuniform List<vector> and internalField nonuniform List <scalar> | Ferdinand | OpenFOAM Pre-Processing | 1 | January 3, 2020 13:20 |
sintax rules to compile setFieldsDict | leske | OpenFOAM Pre-Processing | 2 | January 21, 2016 16:58 |
How can you create a dynamic/calculated internalField? | Dvergr | OpenFOAM Pre-Processing | 0 | October 10, 2014 05:03 |
the internalField entry of U file is not valid in pisoFoam | shuoxue | OpenFOAM Running, Solving & CFD | 5 | November 25, 2013 05:05 |
