2D plane poisuelle flow
Old   June 20, 2018, 01:50
Default 2D plane poisuelle flow
naveen k s
naveen k s is on a distinguished road
Dear foamers,
I am trying to simulate the 2D plane poisuelle flow. I am using icoFoam to simulate the solution. These are my BC's in p and U field. The parallel plates are 2m long, 0.1m in height. Pressure at the inlet is 101.325 and outlet is zero. density is 1000 kg/m^3, kinematic viscosity is 0.01 m^2/s. For these conditions i am ending up with Umax of 12 m/s. Which is twice of the true value. and one more strange thing is with increase in simulation time Umax is also increasing. Anyone there to help me with this?
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
top
type zeroGradient;
bottom
type zeroGradient;
inlet
type fixedValue;
value uniform 101.325;
outlet
type fixedValue;
value uniform 0;
frontAndBack
type empty;
U Field
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
top
type fixedValue;
value uniform (0 0 0);
bottom
type fixedValue;
inlet
type zeroGradient;
outlet
type zeroGradient;
frontAndBack
type empty;
blockMeshDict
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
ConvertToMeters 0.1;
vertices
(0 0 0)
(20 0 0)
(20 1 0)
(0 1 0)
(0 0 0.1)
(20 0 0.1)
(20 1 0.1)
(0 1 0.1)
blocks
hex ( 0 1 2 3 4 5 6 7 ) ( 20 20 1 ) simpleGrading ( 1 1 1 )
edges
boundary
top
type wall;
faces
(3 7 6 2)
bottom
type wall;
faces
(1 5 4 0)
inlet
type patch;
faces
(0 4 7 3)
outlet
type patch;
faces
(2 6 5 1)
frontAndBack
type empty;
faces
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
Last edited by naveen k s; June 20, 2018 at 02:02. Reason: i want to add extra info
naveen k s is offline   Reply With Quote
2d poisuelle flow, boundary condition., maximum velocity
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Setting up a case for a plane plate in a longitudinal flow Chronique OpenFOAM Running, Solving & CFD 0 October 9, 2014 15:17
2D Couette/ Poisuelle Flow CFD Guy FLUENT 1 April 30, 2011 10:48
