An Error in Using groovyBC
Old   May 29, 2018, 10:05
Default An Error in Using groovyBC
A. Min
alimea is on a distinguished road
Hi
I want to create a special BC (boundary condition) in a patch of a cavity. So I used "groovyBC" in such a way:
movingWal
type              groovyBC;
variables       "teta=atan(pos().y/pos().x);r=pow((pow(pos().x,2)+pow(pos().y,2)),0.5)";
valueExpression     vector(-sin(teta), cos(teta), 0)*pow(teta,2);
value     uniform (0,0,0);
conditions      "r<1.008";
but it gives me this error:
continuity error cannot be removed by adjusting the outflow.
Do you know what the reason?
alimea is offline   Reply With Quote
Old   June 3, 2018, 01:22
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I'm afraid you have fixed the velocity on every boundary, so the conservation of volume is not able to be met.
You might want to check the balance between the flow in and out of the computational domain through the boundaries.
[Personal]
fumiya is offline   Reply With Quote
groovybc, outflow
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 08:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 07:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 04:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 08:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 09:49
